March 28, 2024, 12:52:20 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Beginners start here...!
Drive shaft set-up
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Drive shaft set-up (Read 1519 times)
Nordlys
Full Mayhemer
Offline
South East
Drive shaft set-up
on:
May 02, 2012, 07:53:05 pm »
Just had the drive shaft on my boat sieze up today due to using a new 4mm dia shaft in an imperial tube suited for 4ba.
Small difference in dia but enough to cause trouble.
Does anyone know where I can get Fibre washers to put on the shaft behind coupling and propeller.
Assuming that they are really needed?
What is the purpose?
Pete.
john s 2
Full Mayhemer
Offline
Southend on Sea Essex
Re: Drive shaft set-up
Reply #1 on:
May 02, 2012, 08:36:21 pm »
Personally i use stailess steel washers ,brought from my local fastner retailer. From what i see a washer just makes a better trust surface. John.
CGAux26
Full Mayhemer
Offline
Deep in the heart of TEXAS (Tomball)
Reply #2 on:
May 03, 2012, 03:15:42 am »
I use a nylon washer on both ends of the prop shaft. Buy them at my local hardware store in the nuts and bolts aisle for a few pennies each. You don't want the prop or its nut running on the end of the stuffing tube. The thrust forces may grind things down. Let the washer take the wear.
Peter Fitness
Global Moderator
Full Mayhemer
Offline
Wyrallah, near Lismore NSW Australia
Reply #3 on:
May 03, 2012, 07:19:01 am »
Like John, I also use stainless steel thrust washers at both the prop and coupling ends of the prop shaft. Apart from taking the thrust of the prop they also help to keep the grease in the prop tube.
Peter.
Print
Pages: [
1
Go Up
« previous
next »
Drive shaft set-up
