Author Topic: Kyosho Viper Makeover  (Read 6068 times)
armc40
  • Fall guy, it would appear !
« on: May 05, 2012, 07:01:10 pm »
Saw an unused viper outfit on fleabay and although there was an Acomms 27 Meg outfit included I thought that it might benefit from some minor cosmetic touch ups.
Two cans of Holts car sprays later it was beginning to look less like a "toy" and more businesslike.
Mechanical speed controller removed and model equipped with 2.4Ghz radio courtesy of my Corona modified Futaba 8 UP, and 50amp marine speed controller + 3000Ma NiMh.
Finished model looks the part and is yet to be tested on water....roll on good weather.
The motor as fitted is a Le Mans 360 ST and I wondered if anyone out there has any details pertaining to this motor and if replacement is recommended.
Making a mistake is not a sign of weakness. Failure to admit to having made a mistake is though !
Power corrupts whilst absolute power corrupts absolutely. Imaginary power is something else entirely !
Re: Kyosho Viper Makeover
« Reply #1 on: May 05, 2012, 07:54:05 pm »
That is quite a hot motor so I would try it first and see if the performance is what you want.
armc40
« Reply #2 on: May 05, 2012, 08:01:55 pm »
Thanks Bob...just gotta wait for the decent weather to arrive, and when I've posted a bit more I'll have the 27Mhz Tx and RX and mechanical speed controller up for offers  (not really any use to me)
Mad_Mike
  • Lincolnshire
« Reply #3 on: May 05, 2012, 08:12:55 pm »
nob bad find that done a good job with it. where did you get the esc from?
« Reply #4 on: May 05, 2012, 08:26:05 pm »
Good job armc40 !
 I had the IC version of the Viper... what a 'rubbish' engine!!!!
 The engine was so hard to start that eventually I pushed the stand up through the hull whilst pulling on the starting cord!!  >>:-(
.... I converted it to electric after that.  {:-{
armc40
« Reply #5 on: May 05, 2012, 08:32:41 pm »
Mike...if you don't mind the wait, they're available from far eastern Ebay     I bought three... 60 quid and free shipping
Took almost 2 weeks to arrive, but worth the wait    :-)
armc40
« Reply #6 on: May 05, 2012, 08:37:45 pm »
 :P
Good job armc40 !
Still trying to find a suitable battery mounting method for this model as the pics on the carton show it merely resting against the radio box....not recommended surely ?    {:-{
Mad_Mike
  • Lincolnshire
« Reply #7 on: May 05, 2012, 10:24:41 pm »
I use sticky back Velcro for most of my boats. you can buy it from Wilkinson :-)) works just dandy.
I must warn you that the oriental esc's are highly exaggerated regarding there operational limits. If they say 50 amp marine esc itl be more like 15. {:-{ but i wont tar all of them with the same brush maybe these ones might be good, id appreciate your oppinion when you take your boat out  :-))
armc40
« Reply #8 on: May 06, 2012, 10:56:26 pm »
See what you meant Bob....took it out today and that certainly is a punchy little motor....are they still available to buy ?
Andyn
« Reply #9 on: May 06, 2012, 11:35:14 pm »
I had the IC version too, and I managed to pull the engine straight out of the hull.. That was rather interesting...
The engine itself when run in and used on a belt is actually very good, it's just the pullstart that lets it down
« Reply #10 on: May 07, 2012, 03:22:10 pm »
Not sure if they are still available they were marketed as Kyosho motors but they would have been bought in.
It looks a little like the "Palma" motor, but the fast electric boys might be able to give a definitive answer.
armc40
« Reply #11 on: May 14, 2012, 10:32:22 am »
Good job armc40 !
Martin....very simple question but where did you mount the battery in your viper when you converted it to electric ?
If it's mounted to one side as the box art shows, the model sits "lopsided" in the water and I've found that turns are affected as a result and there's not a lot of room to mount it elsewhere.
B
« Reply #12 on: May 14, 2012, 12:28:05 pm »
From memory, 2 x 7.2v Nicads, one on each side, over the the C of G.....
armc40
« Reply #13 on: May 14, 2012, 01:26:44 pm »
Thanks Martin....next on the "to do" list
B
Page created in 0.107 seconds with 22 queries.
