Stavros,
If you mean Hs93's recommendation then the figures don't tally with a 900 motor. Noted Below -
12 v electric motor.
Motor spec:-
Body: 52mm dia 85mm long
Shaft: single end 5.0mm dia ballraced
Commutator: 12 pole, low noise
Voltage: 12v DC
No load RPM: 6700 1.2A
Max efficiency: 5250rpm, 1500g cm, 80w, 6.5A, efficiency 55%
Max power: 3200rpm, 3500g cm, 115w, 9.5A
So we are just arguing for the sake of it? looks to me as if we have 3 different motors now. Personaly i like the T12's and have no issue with them.
