Author Topic: wood deck gratings  (Read 3864 times)
Ted_H
wood deck gratings
« on: May 13, 2012, 08:07:58 pm »
Does anyone have any suggestions or ideas on constructing those wooden deck gratings you see on the open decks of warships. I'm building in 1/96 so it could be a little tedious cutting out all the square block and gluing together. Has anyone any ideas for this scale
So many things to do, and not enough time to do it !
Re: wood deck gratings
« Reply #1 on: May 13, 2012, 09:49:21 pm »
try Jotika caldercraft..here.....  http://www.jotika-ltd.com/Pages/1024768/Fittings/86050.htm
neil.
pugwash
  • Location: recently left Amble and now in the wet Northumberland hills
« Reply #3 on: May 13, 2012, 11:52:49 pm »
to get the right scale at 1/96 try john Haynes fret JRH816 perfect for the job
Geoff
https://www.johnrhaynes.com/shop/index.php?_a=viewCat&catId=10&page=1
Failing to prepare means preparing to fail.
tonyH
« Reply #4 on: May 20, 2012, 05:43:02 pm »
Just as an aside, I've been experimenting to get the effect of gratings as follows.
1. Roll out plasticene so it's flat.
2. 'Scrape' parallel lines/grooves using suitable scale saw blade (normal hacksaw is about 1:96). It helps to have a straight edge along one side.
3. Repeat scraping at 90 degrees. You should then have sort of dimples in a grid pattern which is the 'negative' of the grating.
4. Add plasticene wall around.
5. Spray with a little plumbing silicone spray.
6. Pour in resin to whatever thickness you need plus a bit for fettling.
7. When set, remove and clean up and you should have a 'budget' grating. No holes right through, of course.
8. Clean off any excess plasticene/silicone with a nail brush and washing up liquid.
9. Wash over with well diluted acrylic paint, probably several times. The paint collects in the 'holes' giving an appropriate contrast. As a final wash you can use black or very dark brown to accentuate the shading.
Works for me but..............
Tony
First Pic is after first wash of paint. Second is the finished article.
« Reply #5 on: May 20, 2012, 07:00:43 pm »
Tapestry canvas can work well too, and it is already pretty much the right colour.
CF-FZG
« Reply #6 on: May 20, 2012, 08:49:10 pm »
Geoff
Thanks for the link Geoff, I hadn't seen that site before - some excellent parts :-)) :-))
Mark.
Mark.
Tonka Toys - Big boys toys :)
Page created in 0.391 seconds with 17 queries.
