Model Boat Mayhem - Forum
Pages: 1 [2] 3   Go Down
Author Topic: HMAS Sydney FFG 1:48  (Read 13160 times)
nick_75au
    • Logan City Marine Modellers
Re: HMAS Sydney FFG 1:48
« Reply #25 on: July 30, 2012, 12:21:39 PM »
Ships bell, capstan and one of the several deck hatches.
Nick
nick_75au
« Reply #26 on: August 05, 2012, 03:50:30 AM »
http://www.rcgroups.com/forums/showpost.php?p=22357850&postcount=1124
Couple of photos here of My HMAS Sydney alongside a 1/48 Ticonderoga hull
Teaser
Nick
nick_75au
« Reply #27 on: August 07, 2012, 12:21:40 PM »
Things progress slowly at the moment, I've ordered a small fortune in various carbon fibre round, flat and square to build the main mast STIR and CAS platforms. Ive ordered some Ice fishing rod blanks for the 6 HF aerials, The 76 mm OTO Melara gun and liferaft canisrers are on their way form APS models. I'm still waiting for the couplings for the main shaft.
So while I'm waiting for these things I started on the 02 deck handrails, no pics yet, I've only made about 30 scale feet in 2 days not including the ones I stuffed up due to isometric drawings ) I started out with some copper 6mm cable that has 7 strands of approx .8mm diameter cable, It is just slightly over scale I believe.
I stripped the cores then straightened them, I made a semi jig to space the rails from plywood with groves cut at the required spacing, FFG's dont have one continues rail, its split into sections so as to be removable or folded down for gunnery etc so far the longest portion is 4 verticals long, and each piece has different lengths between verticals.
Nick
nick_75au
« Reply #28 on: August 08, 2012, 07:56:38 AM »
Making the pipe rails
Start with some scrap cable with appropriate sized core, strip it, unravel a strand from the bundle, put one end in a drill chuck, put the other end into a vise or secure it, put some tension on the strand and run the drill back and forth untill the wire snaps in the chuck(be careful not to lean back or you will end up on your backside :} you now have a straight and relatively hard piece of copper wire, put the gut off lengths in the jig and solder, I used some fine copper to secure the horizontal pieces.
Also works for making twisted wire, wire will be shorter than what is cut off, keep the lengths the same when securing in the chuck or it wont look as good, thicker wire lays up a bit better than this 28G I used for demo.
« Reply #29 on: August 08, 2012, 12:51:59 PM »
Nick....if you need some miniture co-axial wiring for the FFG.......I just happen to have a [now semi] complete wiring loom from a Harpoon missile  O0 ...all colour coded....
You would just need the code  {-) .........Derek
nick_75au
« Reply #30 on: August 10, 2012, 12:54:24 PM »
Ha ha nice, Not sure where I would need Co-ax though. You have found some use for it I gather ok2
Slowly going through the rails, Ive made all the rails now from the start of the flare to the hanger back to the hanger, only 3/4 more of the upper deck to do %%
Nick
nick_75au
« Reply #31 on: August 13, 2012, 11:15:14 AM »
Stanchion Production line
Made 43 of the little  :((  Have to see how many I actually need, Got a feeling its a few more <:(
Nick
nick_75au
« Reply #32 on: August 25, 2012, 09:54:23 AM »
A small Update, the driveline has been installed, I used clamp style couplings from E-bay, they are really nice looking units, they seem to be avaiable in many sizes as well, they are quite large diameter but certainly fine for a 1:48 build :-))
Coupling]http://www.ebay.com.au/itm/D-25mm-L-30mm-8mm-X-10mm-CNC-Flexible-Jaw-Spider-Plum-Coupling-Shaft-Coupler-/110877373158?pt=AU_B_I_Electrical_Test_Equipment&hash=item19d0ce72e6#ht_4840wt_906"]Coupling
I'm a bit worried the standard servo not having enough power, the Nexus Tide I built had a similar sized rudder and its servo occasionally stalled
Nick
nick_75au
« Reply #33 on: October 02, 2012, 12:28:51 PM »
Small Update
The Stack, I've got to figure out how to do the Lourves
Put a couple of exhaust fans in it for some ventilation
APS Models 76 MM Oto Melara in primer
Nick
pugwash
« Reply #34 on: October 02, 2012, 02:21:12 PM »
Nick you have the funnel and the fans - have you considered putting a smoke unit in - you should have plenty of room at 1/48 scale
Geoff
glendavis1971
« Reply #35 on: October 02, 2012, 07:06:30 PM »
is shapeways $20 shipping per item or per order?
nick_75au
« Reply #36 on: October 03, 2012, 07:15:32 AM »
On the smoke unit, probably not, not much smoke from a gas turbine or steady state diesel, I wonder how I can simulate a heat haze :P
Plenty of room though :-)
Shapeways is $20 per order but for the UK it will be considerably cheaper $9:50, Uk is an EU country isn't it %)
Nick
nick_75au
« Reply #37 on: October 04, 2012, 08:46:07 AM »
Mast is on the way, used carbon 6 x1 mm carbon strip for the webs, this is not the best way as they tend to split along the "grain" so to speak, Its all held together with thick CA and feels very strong though. the verticals are a combination of 6, 5,and 4 mm tube and all the cross bracing is 3 mm carbon.
I ran out of the 3 mm rod, there is nearly 3 metres of 3 mm rod in it:eek:
Nick
nick_75au
« Reply #38 on: October 09, 2012, 12:48:01 PM »
Port side engine intakes and stack nearly done.
It doesnt show but I used metal siding evergreen with a 2mm styrene strip for the border, I would like to highlight the recesses of the grill with black but I'm not sure how just yet.
Nick
nick_75au
« Reply #39 on: October 11, 2012, 12:40:26 PM »
Nearly there with the main mast. Only a tiny bit more bracing, and then the detailing cable trunks and a whole lot of other pieces.
Nick
nick_75au
« Reply #40 on: November 04, 2012, 05:36:27 AM »
I took her out to the lake today to do a sea trial, I have nailed the motor set-up I reckon, its perfect, draws 21.5 amps at full throttle, 290 odd watts at about 14 volts with a 4 cell Li-po. A surprise was the stabilizer system, it works very well as well, the boat resists heeling when sharp turns are conducted. I tried to get some on board footage, got about 30 seconds and the recorder stopped >>:-(
Anyway a couple of Pics
Grey ship Grey sky
At speed, the performance is very realistic
Nick
nick_75au
Re: HMAS Sydney FFG 1:48 Onboard Video
« Reply #41 on: November 11, 2012, 08:44:28 AM »
« Reply #42 on: November 11, 2012, 09:19:27 AM »
Hi Nick....I enjoyed all those ~~~~ 2:28:30 minutes of her sea trials
1. She seemed to cut through the wake of the A/Bourke destroyer very cleanly  :-))
2. The few transmission moans & groans are non protoypical  :embarrassed:
3. The guide arm on the GMLS13 launcher....should it not face FWD...with or without a bird on the rail? O0
Overall...9.5/10 congratulations.......Derek
nick_75au
« Reply #43 on: November 11, 2012, 09:32:20 AM »
I am very happy with her on water performance :-))
Most of the noise is ESC generated I think, the motor may need an elastomeric mount. Or I need to get Masker working ;D
Like this {:-{  If its not correct I have the technology to rotate the launcher arm :-)
I spent my career down in the ER bilge I know not these things about machinery on the deck :embarrassed:
Nick
« Reply #44 on: November 11, 2012, 10:33:39 AM »
 {-)  ...could the image below of the launcher be on a USN vessel?
rotate the launcher 180 degrees.......depress the guide arm 35 degrees & show a BLUE bird on the rail ...you know what I mean....... O0  ...Derek
nick_75au
« Reply #45 on: November 11, 2012, 10:47:34 AM »
Yes that was a USN Photo
Here is what your talking about :-))  so this is the standard for when at sea? will make the required modifications O0
Nick
nick_75au
« Reply #46 on: November 13, 2012, 07:20:56 AM »
Just a bunch of pics from our Remembrance Day Regatta :-)
nick
Stormbringer
« Reply #47 on: November 13, 2012, 06:05:23 PM »
nice ships  :-))
nick_75au
« Reply #48 on: November 14, 2012, 05:59:53 AM »
Thank you :-))
nick_75au
« Reply #49 on: November 14, 2012, 09:58:29 AM »
Mullets had a bad day, Painted the Helo marks on the flight deck and had massive bleed through, so I had to repaint the deck skid around all the lines :-[
Internals of Stab, a $3.00 servo driving in essence a rudder, the servo is mounted on a 45 Deg plane the same as the control horn. the Stbd side is mirrored, servos are connected to a Y lead which hooks to the Aileron port on the Orange Stabilizer box
Just the outside of the stab.
Pages: 1 [2] 3   Go Up
