Author Topic: Graupner sound switch  (Read 3742 times)
ken224
« on: May 17, 2012, 07:12:27 am »
Hi all
can anyone tell me how to connect my graupner sound switch to my futaba f14, i only want to connect to the seven switch options on the graupner which i believe are negative switches. Unfortunately i can no longer use the proportional channels on the sound switch due to an overload  and a bit of smoke and at the moment i have 8 spare switched channels on my f14
triumphjon
Re: Graupner sound switch
« Reply #1 on: May 17, 2012, 08:18:33 am »
i have three  of the  graupner smx switcher units , and can confirm that they are switched negatives ,
ken224
« Reply #2 on: May 18, 2012, 06:23:07 am »
Thanks for that
my main question is what sort of lead or relay do you use to connect from the multiprop decoder to the input clamp on the soundswitch. I am guessing that you use a futaba lead and just connect the ground or am i wrong. dont want another smoke unit  {-)
triumphjon
« Reply #3 on: May 18, 2012, 07:22:55 am »
sorry ken i dont know , the units i have are connected so the -ve runs from a battery to the switcher the switcher then provides all of my components to be turned on / off , the +ve from the battery completes the circuit , the unit itself is pluged into the rx in the same manner a servo would .
ken224
« Reply #4 on: May 18, 2012, 11:08:38 am »
Thanks for your help hopefully i will get there in the end
john s 2
« Reply #5 on: May 18, 2012, 10:14:37 pm »
Why not give Ripmax a ring. As importers of robbe sets they should be able to help. John.
ken224
« Reply #6 on: May 19, 2012, 06:18:45 am »
will do if and when i find the answer i will post the reply
triumphjon
« Reply #7 on: May 19, 2012, 08:14:19 am »
not much good asking robbe how to set up a rivals product? the item in question is from graupner !
ken224
« Reply #8 on: June 24, 2012, 07:09:19 am »
Sorted it will trial and error i just connected a servo patch lead from the multiswitch directly to the sound switch got all the sounds i need now
« Reply #9 on: June 24, 2012, 09:16:51 am »
 Do Robbe importers give out information on Graupner products.  {:-{
john s 2
« Reply #10 on: June 25, 2012, 11:14:40 am »
Dicky i got that one wrong, sorry John.
Page created in 0.528 seconds with 21 queries.
