Author Topic: smokeyst smoke machine  (Read 9370 times)
ian-mccaffrey
  • roll on mayhem at wicksteed 2016 !
« on: May 18, 2012, 01:16:56 AM »
ok guys some one must know .... who makes the smokeyst smoke machine for the least s ????    or should i say who makes the most smoke for the least s ???? %%
lets just hope this one floats !!
fire at will ! ... which one is will ?
HS93 (RIP)
  • I cannot spell , tough
Re: smokeyst smoke machine
« Reply #1 on: May 18, 2012, 01:23:56 AM »
yep make your own if you want cheap there was an article in model boats no so long ago on how to make one, it's one of the easyest thing to make. I am shore someone will come up with the date it was in.
Peter
ian-mccaffrey
« Reply #2 on: May 18, 2012, 01:35:35 AM »
thanx mate ... any advice or help is muchly appreciated
idealy i want to buy one ...... but if someone could show me step by step that would be even better
Martin [Admin]
« Reply #3 on: May 18, 2012, 09:01:59 AM »
The heated oil based ones produce lots of smoke but take quite a bit of power to run.
Smoke pellets produce the most smoke but are quite short lived....
http://youtu.be/SkYPKqnTQMk
Tug-Kenny
« Reply #4 on: May 18, 2012, 11:00:59 AM »
They can't come much Smokier than that.   %)
ken
john44
« Reply #5 on: May 18, 2012, 12:51:25 PM »
looks like the funnel wants sweeping. {-) brilliant thats the smokiest boat I have ever seen.
what are these smoke tablets? are they prescription only? {-) {-) {-)
john
ian-mccaffrey
« Reply #6 on: May 18, 2012, 01:11:33 PM »
john
http://robotbirds.com/catalog/index.php?cPath=129_128
Arrow5
« Reply #7 on: May 18, 2012, 03:26:57 PM »
Beware of the "black" ones , it is more of a dark purple-ish colour.  Maybe mixing in some other colour might work, ie two pellets each different. Expensive way to experiment :((.  That pellet was a 90second one, I split them down the middle and put one half on top of the other. They have to be in a metal tube and away from plastic, they get very hot, dont forget it is a slow burning firework. :o
..well can you land on this?
nemesis
« Reply #8 on: May 18, 2012, 06:45:53 PM »
Hi, We used a smoke bomb (Drain Tester) to simulate a vessel on fire, plenty of smoke with this one. Nemesis
ian-mccaffrey
« Reply #9 on: May 18, 2012, 07:21:10 PM »
but not the every day smoke out of the funnel look that im looking for .... i work for a firework company . and i can certainly make things smoke .... just not what im looking for ... any one make good smoke machines out there
tugs62
« Reply #10 on: May 18, 2012, 07:23:49 PM »
i got a grunpner 6v off ebay for  10 and run it with 3 in 1 oil and i get loads of smoke
Tug-Kenny
« Reply #11 on: May 18, 2012, 08:09:03 PM »
Marks Model Bits have been doing smoke generators for a while now. These use plain water and no heat.
                         http://www.marksmodelbits.com/
ken
ian-mccaffrey
« Reply #12 on: May 18, 2012, 08:12:24 PM »
have you got any video of yours and maybe a link to the one you got
tugs62
« Reply #13 on: May 18, 2012, 10:08:16 PM »
i will try and put some pics up
john s 2
« Reply #14 on: May 18, 2012, 10:11:46 PM »
Sadly there is no thing as a free lunch. With any unit more smoke means more power. There are pros and cons for both oil and water foggers. Personally i use water foggers. You can buy off E Bay tripple foggers. To be built into your own case etc. But they take three times the power, about two and a half amps 24v. John.
tugs62
« Reply #15 on: May 18, 2012, 10:42:55 PM »
thats just 3 in 1 oil
ian-mccaffrey
« Reply #16 on: May 19, 2012, 12:01:26 AM »
thank guys ... i got a hunter systems smoke generator .. and to be honest . its pritty dam good . so i might play about with different oils ..
.http://shop.huntersystems.co.uk/smoke-generator-tm-141-p.asp
red181
« Reply #17 on: May 19, 2012, 08:16:30 AM »
this is mine in my Orca, its home made, and is the hot oil type, inefficient, but works great :-))
http://www.youtube.com/watch?v=ZmEngFE3EKg
then I modified it, to recreate the engine about to blow up :}
http://www.youtube.com/watch?v=E1wLQvMgW24
baloo
  • I`M YOUR FRIENDLY TRUCKER
« Reply #18 on: May 31, 2012, 08:11:55 PM »
It`s a bit long winded,but here goes:- 1.a piece of 22mm copper tube(approx 1 1/2")
                                                      2.wick (1/2" x 1" strips)
                                                      3.oil (veg oil,car oil,3 in 1 oil)
                                                      4.box of matches/lighter
Drill holes in copper tube all over,soak wick in oil,drain excess oil off and set alight(adult supervision req).Singe one end,and when glowing blow flame out,put wick into copper tube(put copper tube  a 1/3 of the way into the  funnel)lasts about 20 mins(very effective)one last thing before i go,about 6 to 7 yrs ago i soaked the wick in breakfast oil,and when my tug was going round the course in a compitition you could smell the "breakfast" and people were saying i need either a bacon or sausage roll that`s making me hungry.costs peanuts to make (less than a fiver).baloo
ian-mccaffrey
« Reply #19 on: May 31, 2012, 09:28:57 PM »
lovely ... thanx guys ..... i think im sorted
john44
« Reply #20 on: May 31, 2012, 11:26:37 PM »
Excellent, but how did you make it? and what from?
john
ian-mccaffrey
« Reply #21 on: June 01, 2012, 05:12:17 PM »
i got a tupperwear box . cus a 10 mm hole in the top . and a 40 mm im the bottom .... then i used hot glue with a computer cpu fan and stuck it over the big hole ... then i opened teh box and put inside an old agtion electronics smoke machine .... turn the smoke machine on ... let it heat up ... then turn the fan on .  and it blows out plenty of smoke !!!!
ian-mccaffrey
« Reply #22 on: June 01, 2012, 05:14:20 PM »
 its actually ahunter systems one i got not the action electronic one lol .... i dont even know if they make one haha
john44
« Reply #23 on: June 01, 2012, 10:12:58 PM »
john
ian-mccaffrey
« Reply #24 on: June 02, 2012, 12:12:05 AM »
i will add pics and a video later in the week so keep a look out !! :-))
