Author Topic: Rubber Beading/channel  (Read 4851 times)
Nordlys
« on: May 18, 2012, 06:32:13 pm »
Does anyone know if its possible to obtain rubber channel  material for beading around
windows.
My boat has damaged beading pushed into the window openings on the plywood superstructure
which I would like to replace. The glazing sits on the beading and is secured on the inside.
Nordlys....
nemesis
Re: Rubber Beading/channel
« Reply #1 on: May 18, 2012, 06:40:22 pm »
Hi, A long way around your problem is to make a mould & make it in silicone, Nemesis.
Nordlys
« Reply #2 on: May 18, 2012, 06:44:46 pm »
If I'm honest with you I wouldn't know where to begin!
Nordlys
« Reply #3 on: May 18, 2012, 07:10:43 pm »
As you can see the rubber beading does not look too good.
I would be very pleased to find a source to replace most of it. Slightly
larger size on the windscreen.
I'm hoping someone is familiar with this beading style.
Thanks,
Nordyls....
Kangaroo1
« Reply #4 on: May 18, 2012, 09:00:07 pm »
Nordlys, in the absence of any suggested model shops/outlets, you could try the following (C.O.H Baines). They may be able to help...
http://www.coh-baines.co.uk/
Nordlys
« Reply #5 on: May 19, 2012, 02:52:12 pm »
I am emailing them now in the hope that they may supply beading
of this small size!
Failing that it will have to stay as it is!
Nordlys..
nemesis
« Reply #6 on: May 19, 2012, 06:29:55 pm »
Hi, after seeing the boat another way is to get plastic covered wire & slit it down the length with a scalpel, withdraw the wire & slot the plastic U section over the frame, Nemesis
Nordlys
« Reply #7 on: May 20, 2012, 08:48:52 am »
Yes, I think that may well be the easiest method and quite do-able.
Thanks, off to find some cable!
Nordlys...
armc40
  • Fall guy, it would appear !
« Reply #8 on: May 20, 2012, 10:59:47 am »
Hello
Know it's a long time ago but I used to use silicone fuel tubing of various diameters split with a small pair of nail scissors (safer than a scalpel) and then used either silicon sealant or cyano to secure it to the frame.
Bill
Making a mistake is not a sign of weakness. Failure to admit to having made a mistake is though !
Power corrupts whilst absolute power corrupts absolutely. Imaginary power is something else entirely !
Nordlys
« Reply #9 on: May 21, 2012, 07:33:44 pm »
I tried stripping cable for the outer covering but it hasn't been that successful
it doesn't take small radius bends too well.
Have contacted C.O.H Baines (earlier suggestion) and they are sending a sample
93p per metre. £10 min order charge tho.
Worth a try I thought.
Nordlys.....
hmsantrim
« Reply #10 on: May 21, 2012, 11:54:46 pm »
 Hi Nordlys.
                 u channel fender on E-bay may be the thing.
                http://www.ebay.co.uk/itm/120768638686?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 model shop
               or E-bay search category  http://www.ebay.co.uk/sch/i.html?_kw=EDGING&_kw=rubber&_dmpt=UK_Men_s_Shoes
                                    cheers Frank.
Nordlys
« Reply #11 on: May 23, 2012, 07:48:48 pm »
Thanks Frank.
I received the sample from COH Baines, very good of them and so quick,
but it was too chunky. It fiited over the ply and formed round the window frame nicely
but rubber section was just that bit too thick.
I think the Ebay listing was also too big.
Chatham Dockyard models is supposed to have some I am informed,
so a visit down there shortly.
chuffy
« Reply #12 on: May 24, 2012, 09:52:05 am »
You might like to consider this glazing strip, very neat and unobtrusive, not a bad price either. The glazing needs to be the same size as the opening. I have used it on all my scale helicopters with excellent results.
http://www.vario-helicopter.biz/gb/product_info.php?products_id=31159
Paul.
The severity of the itch is inversely proportional to the length of your reach.
Nordlys
« Reply #13 on: May 24, 2012, 02:11:50 pm »
Hi Paul,
Now that looks much more promising.
In the Technical description it refers to "the 'S' section".
It looks very much like a simple U section in the picture to me?
Can you describe it please.
I wouldn't necessarily put perspex glazing in the channel
but I would glue the perspex window on the inside up against the beading.
Have you seen the pictures further back?
Thanks for your help - a reasonable price for 2mtrs  too.
N.
Page created in 0.041 seconds with 21 queries.
