Author Topic: Brass props for Revell Type VII  (Read 5315 times)
redboat219
« on: June 14, 2012, 12:02:03 pm »
Any recommendations?
"Better is the enemy of good enough"
Re: Brass props for Revell Type VII
« Reply #1 on: June 14, 2012, 06:01:57 pm »
What size do they need to be?
http://www.modelboatbits.com/
redboat219
« Reply #2 on: June 14, 2012, 11:50:06 pm »
3 blade 20mm diameter.
salmon
« Reply #3 on: June 14, 2012, 11:52:12 pm »
Here is what I found,
I have not verified this guys statements, but it seems accurate.
http://www.scribd.com/doc/75867108/98/Stern
To summarize: "The kit plastic would not do, so I bought Raboesch brass props: 20mm (3/4" or .79") A-type, Left and Right.
These are excellent quality - highly recommended for any naval project. The more exact scale would be 22mm, but is not made."
Peace,
Tom
If you can cut, drill, saw, hit things and swear a lot, you're well on the way to building a working model sub.
CF-FZG
« Reply #4 on: June 14, 2012, 11:52:45 pm »
Try here the top 2 on the page are the ones you want :-))
Mark.
Mark.
Tonka Toys - Big boys toys :)
redboat219
« Reply #5 on: June 15, 2012, 01:28:21 am »
Thanks guys.
I recently came across the G-Factor scale brass props for scale models. They have a set for the Revell Type VII.
http://www.hannants.co.uk/search/?manufacturer_id=309420
Does anyone here have experience with them? Can they be used for RC or are they solely meant for static use?
CF-FZG
« Reply #6 on: June 16, 2012, 12:05:56 am »
They look like static 'detailing' props, I'm getting the Raboesch ones for mine :-))  but I'll get them from Caswell so they fit my prop-shafts which are 1/8"
Mark.
Mark.
salmon
« Reply #7 on: June 16, 2012, 12:24:08 am »
On my Revell Gato, I have a set of Caswell white metal, G-Factor, and Raboesch. The g-factor looked like the models plastic prop recast. The Raboesch were more like the Caswell ones in size. I put the Raboesch on and they have been great. What are the mm size of the G-Factor?
Subculture
    • Dive-in to Model submarines
« Reply #8 on: June 16, 2012, 08:04:52 pm »
wullie/mk2
« Reply #9 on: July 30, 2012, 09:52:45 pm »
An interesting accessory for Revell type V11
http://www.ebay.co.uk/itm/200796869019?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
in case your German is limited,...it a wooden deck overlay,
Wullie,s place is an apology free zone
