Author Topic: HMS HOOD - As grandad would have done it  (Read 17694 times)
joppyuk1
« on: June 15, 2012, 12:22:23 pm »
This is my current project (not counting the ones on the back burner) and I hope to bring it to fruition fairly rapidly, for me at any rate, I once took three years to make my wife a spice rack! Without going into too much preamble, it involves building a 24inch electric powered HMS Hood from a plan available from Hobbies in 1940.
In order to make the build interesting I'm going to try doing it as it would have been done then. So, it's wartime, materials scarce, a basic tool kit (powered fretsaws were available, but no major power tools in the average home), glues were basic so no PVA, etc.
this is the design sheet. thanks to Derick Scott of www.model-plans.co.uk
and part of the instructions
finally, the basic tool kit, taken using details from the 1940s annual. Other items will probably creep in, but with care.
I hope to provide weekly updates if there is interest.
Bob K
  • Bob K
Re: HMS HOOD - As grandad would have done it
« Reply #1 on: June 15, 2012, 12:45:37 pm »
This looks an interesting project Ian, especially the way you are doing it.  Please more details and photos as you progress.   :-))
Mad_Mike
  • Lincolnshire
« Reply #2 on: June 15, 2012, 02:42:33 pm »
what a great idea. what glues did they have in 1940? will it be rc?
« Reply #3 on: June 15, 2012, 09:00:44 pm »
What an unusual project.  I shall look forward with interest as I'm sure it will bring back many childhood memories.   :-)) :-))
Some of the members might be able to assist with factual details on various aspects and I hope to 'chip in' myself.  Mind you, some of it might be worthless as your talking to ex child who cut the mains lead with a pair of scissors.  <:(
ken
« Reply #4 on: June 15, 2012, 10:06:27 pm »
ken
 :embarrassed: I put a spoon in a 3 bear electric fire  :embarrassed:
« Reply #5 on: June 16, 2012, 11:22:43 am »
The only way to learn ..............................................................  <*<
This would make an interesting thread so I'll start one up and let  joppyuk1  get on with his.
cheers
ken
joppyuk1
« Reply #6 on: June 18, 2012, 08:54:37 am »
A little progress report is in order, and as I'm working ahead of my typing things are a bit further advanced than they may appear. I have been busy with the fretsaw, cutting the lifts from half-inch and quarter-inch balsa, and while recovering from cramp in the right hand I've put down a few preliminary thoughts.
My intention is to use the wartime 'make-do' ethos, by using whatever I have on hand, rather than going out buying the proper stuff. I'm sure that is probably how it went on. According to the plan I should be using deal for the hull, but this would mean shoving some planks through the thicknesser, which is against my rules! I have plenty of balsa about, so I'm using that.
According to the instructions I could buy a kit of wood (deal and satin walnut), dowel, motor, propeller, blade and shaft, wire, 8 turned metal guns, and screws, foor 11/6 plus 1/- postage. For comparison I did a quick check on current hobbies prices for the timber only, and this comes out at - balsa £30, obeche £82, and spruce £104. I have a prop and shaft but the only two motors lying around are a)too big or b)too small, so I'm going to have to purchase one.
Choice of glue was a problem. Modern glues are not allowed and a check of the 1940 annual shows only a choice of 6 adhesives. Two are paper pastes, then we have Tenastine, Ste-Fix, Hobbies Glue (all in tubes) and Croid Aero Glue in a tin (needing hot water to melt it). I haven't got any Croid (which I remember my father using) so I'm using clear tube UHU, as it's water-resistant and paint should seal it.
More pictures of progress next time.
Mad_Mike
  • Lincolnshire
« Reply #7 on: June 18, 2012, 12:19:32 pm »
keep the pictures posted fella :-))
dreadnought72
« Reply #8 on: June 18, 2012, 07:17:09 pm »
I suppose, if grandad had access to a Mosquito factory, he could have "acquired" some aerolite (urea-formaldehyde) glue.  :-)) %)
(Great idea for a thread, btw.)
Big Ada
« Reply #9 on: June 20, 2012, 06:22:21 pm »
I bet that put them off their Porridge!!! O0
« Reply #10 on: June 20, 2012, 08:00:52 pm »
hi ya there
enjoying the build  :-))
I did something similar to this a while ago, with the Hobbies plan of the launch where I only stuck faithful to the plan and its method of build - but not to the materials - I used modern day materials.   Its somewhere on this forum under 'the year I was born' title.
When was Cascamite glue first produced?
was it in the 40s or after the war?
cos that would be a suitable glue, if you can use it.
aye
john
joppyuk1
« Reply #11 on: June 23, 2012, 09:26:14 am »
A couple of answers first. Mad Mike, no it won't have rc, mainly because the original didn't have and I doubt the 'average' chap would have access, especially in wartime. There is probably room for a small modern set-up inside the hull though, so it could be done. Bluebird, as far as I can find out, Cascamite didn't come along until the early/mid 50's, much like many of the other wartime developements. I said earlier that the 1940 handbook had a limited number of glues listed, by the 1945 issue this was zero!
Here's the completed hull, just needs lots of sanding to get the shape and lose all the irregulatities. The plan had no hull sections, or indication on its shape at all, so it's basically a slab-sided box pointed at both ends
this shows the lift-out deck section giving access to the batteries. I'm off to the bike shop later today to see if I can still get the old flat battery used in bike lights. There is no allowance for a battery box, in fact the picture in the instructions just shows the batteries sitting loose on the hull floor.
That's progress this week, it's going slower than expected as real life keeps getting in the way, and I've got at least three other, unrelated, projects on the go at the same time.
« Reply #12 on: June 29, 2012, 07:01:12 am »
you may well be out of luck if its the battery I'm thinking of
I think the battery you want is the ever ready 800... I was looking for one a while back for a neighbors bike
http://brassgoggles.co.uk/forum/index.php?topic=14394.0
Have a look in the first post and if thats the same as the one you are looking for then please let me know if you manage to find a supplier as I had no luck at all.
We ended up making a custom battery box that took 2 AA cells,
joppyuk1
« Reply #13 on: July 01, 2012, 09:52:57 am »
This weeks instalment has been a lot of painting, sanding, painting, sanding, painting ... you know how it goes,(a couple of primer pots I have left over, Barracuda Red and Dove Grey)  but in the meantime I've been roughing out the pieces for the forward superstructure. This consists of an assortment of solid shape from 1/4inch, 3/16inch, 1/8inch, and 1/16inch timber, all to be shaped and sanded then glued one on top of the other. The photo should give you some idea. I've also been trying to track down the correct batteries, either an Ever Ready 800 or a 1289, but local shops (bike, electrical, and hardware) seem to think they are discontinued - apart from one chap who shall be nameless, telling me 'if it's not on the rack we haven't got it'. The wartime ethos of the build tells me I musn't try online.
A piece of the instructions shows the arrangement.
The other thing I've been trying to work out is, how the switch works. I can see it's a simple contact switch turned by moving the turret, but the instructions give no indication how to p
ivot the turret to make contact. Also, the switch is open to the elements at one side, so I can see water causing problems. This is one instance where I might revert to a normal push switch.
see you
« Reply #14 on: July 01, 2012, 10:30:49 am »
I think with regards to the battery. You could source one online and not be breaking with the "as grandad did it" ethos, as the batteries would have been avaialble almost everywhere at that time
« Reply #15 on: July 01, 2012, 12:01:07 pm »
I'm fairly sure that the "flat" batteries were 4.5 volt 3 cell jobbies intended for use in flat pocket torches, each cell the same proportions as, but bigger than, an "AA".  They were good for models because you could hook the wiring up using paper clips.  The bike front lamp batteries were usually 3 volt types, two cells a bit bigger than present day "D" cells.  Since the rules back then limited you to what was available, I can't see a valid reason to avoid substituting a modern equivalent.  If it had been made back then, and still existed, and you wanted it to run again, you would fit modern batteries anyway.
I well remember Tenacatine - you could get it from the corner sweet/tobacconist/lead soldier shop, and it did a great job of sticking Micromodels and Bilteezi card models, but, as I found out, it was very water soluble.  Back then for sticking wood it would probably be the stuff made from melted bits of animal that you had to heat in a kettle - and then hoping that the paint would keep the water out.
Stick with the story that grandad had a mate who worked in a shoe factory - certainly immediately post war and possibly during the war, in that trade they used a rubbery glue that was called "solution", and was later to appear in shops as the original Evo-stick.  At least, it looked, acted and smelled the same.  The UHU is probably a good substitute, but I have a vague feeling that UHU is/was a German company, so its products were probably in short supply then.
Raymond
« Reply #16 on: July 01, 2012, 12:37:36 pm »
see you
sadly these batteries were discontinued a few years back,we called them bell batteries as thats what powered most door bells at that time.My first scale model battleship was powered with 4 of these connected together using paper clips, and driving a 46" boat with two 3-6 volt orbit motors on 4 shafts ,and gave a reasonable scale speed for around an hour before running down,the best bit is they were also cheap as well.
joppyuk1
« Reply #18 on: July 12, 2012, 01:21:40 pm »
Things have been a little slow this last couple of weeks because, first, my elderly mother (94) was rushed into hospital about ten days ago after a fall and she is still undergoing tests and treatment, so we've been doing some long distance visiting (she lives in Lincolnshire while we're in Suffolk), and second, I somehow misinterpreted part of the instructions for the forward superstructure and had to remake most of it. The photos show progress to date.
finally, I'm having problems with the secondary armament along the sides. These are basically blunt triangles of 1/8inch wood with a piece of metal rod pushed through, and I have so far made two units and spoiled quite a few more. I will have to use a smaller diameter metal rod and drill carefully. A modern mini-drill would have made short work of it! The photo shows what I mean, though I apologise for the poor quality.
dodgy geezer
« Reply #19 on: August 12, 2012, 12:34:32 pm »
What date are we talking - 1940? I don't think balsa of that size would have been available then - something like obeche might have been - though I could be wrong on that.
I'm a bit surer that the KaKo motor would not have been available. The plan shows a Trix motor, and these are readily available from ebay. There are three there at the moment, including one as a 'buy it now' for £15  http://www.ebay.co.uk/itm/Vintage-Trix-Permag-Electric-Motor-DC-4-8-Volts-Box-A545-/251117299333?pt=UK_Trains_Railway_Models&hash=item3a77c1e685 That has a box - the others are auctions but will probably be cheaper...
joppyuk1
« Reply #20 on: August 12, 2012, 01:01:03 pm »
Thank you for that info, I'll look into the motor. I'm trying to stick to the principle of using what I have available at the moment, lying around in the shed. So far. touch wood, I have not had to buy anything. I've made no progress over the last couple of weeks as I have to keep visiting my elderly mother in Lincolnshire, who is on extended hospital stay and likely to remain so for some time, and as shes 94 in a couple of weeks it's no joke.
Jonty
« Reply #21 on: August 12, 2012, 01:16:53 pm »
  Re battery:
  http://www.vintage-radio.net/forum/showthread.php?t=63415
  but I bet someone somewher in India still makes 'em.
I eat my peas with honey,
I've done it all my life;
dodgy geezer
« Reply #22 on: August 12, 2012, 02:10:21 pm »
The batteries are no problem at all. The ones shown in the plan are not 800s but 3R12s.
3R12 4.5v batteries are still made by several companies - Just google '3R12'. Here is an example - http://www.smallbattery.company.org.uk/sbc_3r12.htm . If you want a really poor performance you can still buy the original zinc-carbon ones! And you can get adaptors as well if you want use Ni-MH cells but still keep the flat battery pack...
pettyofficernick
« Reply #23 on: August 12, 2012, 03:55:17 pm »
Wasn't 'Scotch' glue available in the 40's, the stuff you melt in a pot, made from animal bones and comes as little brown pellets. I think It was used for veneering...
Nick. :-)) :-)) :-))
Big Ada
« Reply #24 on: August 14, 2012, 06:02:53 pm »
The smell of that hot glue takes me back to woodworking classes at school, at 15 I made a pair of 5 tread steps.
Children nowadays do not get the oportunities to do anything as there are no workshops in schools.
Len.
