Author Topic: Oil in the pond  (Read 4671 times)
Rob1962
Oil in the pond
« on: June 17, 2012, 02:20:17 pm »
When i run my Cheddar puffinn i see a covering of oil in the pond everytime irun it is a Bespoke boiler.Thanks for any info.
Proud owner Krick Victoria & Krick Borkum.Cheddar Claire/pintail E & B
Re: Oil in the pond
« Reply #1 on: June 17, 2012, 04:25:02 pm »
Either build a model Fire Tender and use the monitors to spray detergent or couple the engine exhaust to an oil separator.
Andyn
Re: Oil in the pond
« Reply #2 on: June 17, 2012, 04:27:07 pm »
Or not worry about it. It's one part per trillion :-))
Re: Oil in the pond
« Reply #3 on: June 17, 2012, 04:43:02 pm »
No Rob, do all you can to try to solve the problem. Ignoring it tends to really p*** off the "Authorities" who may be controlling your "Ocean"  O0
   Regards   Ian.
nemesis
Re: Oil in the pond
« Reply #4 on: June 17, 2012, 05:44:07 pm »
Hi, Try vegetable oil, it is biodegradable or get Castrol "R". I would not worry too much when you see all the C**p that comes off swans, it is a dirty scum together with feathers. Also see the mess when pigeons take a bath. Nemesis
Re: Oil in the pond
« Reply #5 on: June 17, 2012, 07:22:48 pm »
Differance is, those in charge have problems prosecuting nature but you could be in front of the beak. Go back in Mayhem's archives re the restriction of fire powered boats on one boating pond.
  Regards  Ian
HS93 (RIP)
  • I cannot spell , tough
Re: Oil in the pond
« Reply #6 on: June 18, 2012, 12:26:40 am »
you cannot use Castrol R you need to use Steam oil and have an inline oil separtor all cheddar plants where supplied with one.
 try
http://www.clevedonsteam.co.uk/
Rob1962
Re: Oil in the pond
« Reply #7 on: June 18, 2012, 04:00:11 am »
I am useing an inline oil seperator still getting oil in the pond tho.
HS93 (RIP)
Re: Oil in the pond
« Reply #8 on: June 18, 2012, 06:43:53 am »
are you using steam oil ? and is it a standard displacement lubricator have you got a picture of your installation in your boat.
Peter
Re: Oil in the pond
« Reply #9 on: June 18, 2012, 07:19:03 am »
Have you an oiler on your propshaft that is seeping lubricant into the water.
Alittle oil goes a long way on calm waters.
That is assuming your separator is oil tght and doing it's job.
Just a thought
Andyn
Re: Oil in the pond
« Reply #10 on: June 18, 2012, 09:39:03 am »
If you're losing oil through the shaft, then use grease :-))
Hallettoil
Re: Oil in the pond
« Reply #11 on: July 19, 2013, 07:47:11 pm »
Hello
There may be a possibility that you are over oiling and excess oil is exhausting. It takes very little to make a pretty picture :-)
I manufactured steam oils for a living and a huge amount of problems were caused by over oiling. It's a thin line between not enough and too much..be patient.
I'm also assuming that you are using the correct steam cylinder oil, this is important. Never be tempted to use anything else. You will endless problems.
If you have a lubrication issue, feel free to contact me
Best regards
Richard
Page created in 1.08 seconds with 21 queries.
