Author Topic: switching motors  (Read 4461 times)
subs1
switching motors
« on: June 18, 2012, 04:06:56 am »
Hi all . I thought I posted this yesterday , but it's not showing so I will redo.
I am building a DUKW and being the cheap person I am , I would like  to know it there is a simple way ( or electronic ) to switch between using one speed controller ( Mtronic ) to operate the land drive and then  use microswitches or electronic gee-jaw to change from that drive  to a different motor (  using the same speed controller ) driving the prop motor ? The land drive motor draws 10-12 amps loaded . I hope I have made that clear enough  ?
 Thanks . malcolm  NZ
Re: switching motors
« Reply #1 on: June 18, 2012, 11:58:37 am »
The are electronic change over switches you can use.  Flick the control arm to one side and it locks a changeover circuit which switches a heavy relay. This should be enough for your motors and save an R/X into the bargain.
ken
« Reply #2 on: June 18, 2012, 12:10:52 pm »
There maybe a problem if one , both or either speed controller is using BEC - you might loose control or burn up your receiver.
I would have though the easiest/safest way was to have the prop speed controller on a separate channel...
« Reply #3 on: June 18, 2012, 12:27:46 pm »
There was a chap on here last year who did a kit that does just what you want
Switched steering to rudder and speed controllers via another channel... you do need a seperate reciver battery and 2 drive batteries tho
I was looking into to doing a deans DUKW, but never managed to find the running gear I wanted cheap enough (Tamiya tractor truck)
TomP
« Reply #4 on: June 18, 2012, 02:38:01 pm »
Could it be done using a double pole, double throw relay with a 5v coil which could be switched from the Tx? bit of a rough drawing show what I mean
ACTion
« Reply #5 on: June 18, 2012, 02:42:24 pm »
I suspect that was Pete Keirle ('PMK') who sadly died earlier this year. I don't have the code for the PIC he used.
Ref the question, why not have both motors connected in parallel to the same ESC and thus engaged at the same time? The road wheels won't present any load when the craft is on the water and the prop won't be under any forces when on the road. It also makes switching over very easy (i.e. you don't have to) and the transition from water to land and vice verse should be very smooth.
No need to make things complicated. Just make sure you have a decent speed controller of at least 20A - I can recommend one if you're in any doubt  8)
DM
6705russell
« Reply #6 on: June 18, 2012, 03:01:26 pm »
Yes it can be done that way, but by the time you have bought the materials (including a switcher to operate the relay to do the job) you may as well buy a £20 speed controller.....
Russ
« Reply #7 on: June 18, 2012, 03:02:44 pm »
DM
Thats the chap!
I never realised he had passed away :( such a shame.... a really nice chap!
With regards to the PIC code.. could his code be read back from the chip so that someone could continue to make them?
ACTion
« Reply #8 on: June 18, 2012, 04:07:18 pm »
Nope - 'fraid not; it's encrypted. As Pete himself might have said, 'I might be a thick, two-bit yokel but I ain't stupid'!
Dave M
« Reply #9 on: June 19, 2012, 06:28:35 am »
Fair enough.
I think Ill hold on to my unbuilt one and sell it on Ebay in a few years lol
subs1
« Reply #10 on: June 19, 2012, 09:32:26 pm »
Thanks guys for the input . And no , I'm not using BEC as I prefer a separate RX battery pack .
regards , Malcolm  NZ
Page created in 0.212 seconds with 21 queries.
