Author Topic: Parrallel Batteries  (Read 3928 times)
lakeshore
Parrallel Batteries
« on: June 22, 2012, 05:51:03 pm »
Hi
just wondering about the pro's and cons of fitting two 7.2v batteries wired in parrallel to drive a single 6-9v motor through mtroniks 20amp viper marine and Bec.
John.
gwa84the2nd
Re: Parrallel Batteries
« Reply #1 on: June 22, 2012, 05:56:55 pm »
basikly pro's more run time cons bit more weight  :-))
lakeshore
« Reply #2 on: June 22, 2012, 07:26:45 pm »
Not really bothered about weight issue got plenty of room.More interested in runtime.
« Reply #3 on: June 22, 2012, 08:16:31 pm »
Yes you might as well make the ballast work for you, and you can get the run time you want too.
I had this recommended to me recently by someone I trust http://www.electronize.co.uk/fr30_series.htm and I'm told they can be repaired too, whereas some others are throwaway. This was posted up recently too http://www.howesmodels.co.uk/RadioControl/viewProduct.php?ProdID=5695. I'm sure someone here will advise you of the best buys when you have the motor and prop info to hand. There are some bad buys out there too that can burn your boat so it's good policy to ask first buy later.
« Reply #4 on: June 22, 2012, 09:45:43 pm »
And of course ACTion have a module for connecting two batteries in a safe and tidy manner - theres a recent thread about that somewhere near.
pettyofficernick
« Reply #5 on: June 22, 2012, 10:27:58 pm »
Hi John, Use the ACTion P103 parallel power board, I am in the middle of installing one this very minute.
http://www.action-electronics.co.uk/pat.php
Nick. :-)) :-)) :-))
tobyker
« Reply #6 on: June 22, 2012, 11:11:24 pm »
I like that hull.
lakeshore
« Reply #8 on: June 23, 2012, 06:00:45 am »
Thank's for the link Nick.
Niall
« Reply #9 on: June 23, 2012, 10:53:20 am »
It is dangerous to attach rechargeble batteries in parrallel.
If 1 cell in 1 battery fails the other battery will discharge into it, which will almost certainly cause a fire.
I don't know if the products other people have posted will protect against this problem.
petermun
« Reply #10 on: June 23, 2012, 11:17:00 am »
Dave, I know the answer, but better coming from you.  Pete
ACTion
« Reply #11 on: June 23, 2012, 11:37:02 am »
P103 is specifically designed to prevent this. (Pete - you were right!)
DM
pettyofficernick
« Reply #12 on: June 23, 2012, 06:52:32 pm »
Hello John, Here's a photo of the P(% I fitted last night, there is more on my Bugsier 3 build, where you will be able to see the complete layout.
lakeshore
« Reply #13 on: June 24, 2012, 07:20:20 am »
Cheers Nick will certainly take a look.
John.
