Hi Alan thanks I also the Airfix HMS Illustrious in my plastic kit stash thats sceam out to be converted to R/C
I did consider a mixer malcom but wanted to see how she runs with rudders first, but its still an option and theres a v tail mixed in my bits box
Hello george I got your message and working on it lol. I and anticipating stability probs and will proberly end up fitting a removable keel to lower the C of G. I used this system on HMS Opal which before keel rolled all over now a very stable model on the water
You just see the keel in this pic
Thanks for the offer essex I also have loads of those servo. they are very reliable I have one thats been to the bottom of the pond and still works a treat
Part 1
Running gear Installation
1/ Prop shaft supports (sorry guy not sure what this bit is called)
As you can see the supports come in 2 halves which with the supplies shafts just glue together. As i'm using proper prop shafts I needed to modify the support by first using a round file to enlarge and deepen the shaft tube in the plastic. Then I made spacers from 1mm plasticard to a total of 2mm to widen the space enogh for a nice fit of the shaft. I glued the pieces together and when dry pushed the shafts into the supports
2/ Motor Mount
The motor mount is used directly from the kit the only modification was for the mounting screws
3/ Motor and Shaft Fitting to Hull
I placed the motor mount and shaft supports loosely into the hull. The hole for the supports required a little widening to allow the shaft support through. While loose i fitted the coupling. the really was very easy as the motor mount was made to the exact angle to match the shafts and the simply lined up so a dab of liquid poly to hold in place then i glued the whole thing in place.
Once dry I used my own melted plastic sulution to strengthen the joints
