Author Topic: Help - problem repairing my bait boat  (Read 8977 times)
Granvitas
« on: June 27, 2012, 05:00:44 pm »
Hi all,
This is my first post so go gently with me...
I managed to pull the aerial through the housing of my Angling Technics Standard bait boat and have taken it apart with a view to repairing it myself (I'm doing this as it cost me a fortune to get it serviced and it's in a much worse condition now).
Whilst the repair of the aerial looks straightforward, I have tested the battery and it's flat and won't take a charge. The problem I have is I'm not sure how to get the old one out to replace it. The battery rests on the bottom of the hull of the boat and I was expecting it to be siliconed in place, but it's stuck solid. I'm not sure what it's been stuck with, so don't know where to start.
The stuff holding down the battery is grey in colour and is set hard.
Any ideas what it might be and how I might shift it?
I thought that I could cut around it (through the 'glue' - not the boat!), but can't really find a suitable tool to do it with. The craft drill 'angle grinder' type of tools can't be used due to the shape of the hull. I was thinking maybe a heated up angled pick might do it but I'm not confident that my hand is steady enough not to damage the hull or that this will actually loosen up the 'glue'.
Can you suggest a tool that might help (and if so where can I buy one)?
I was even considering hacking the battery apart but thought I'd seek some help first.
Thanks for reading and thanks in advance for your help.
Pete
Re: Help - problem repairing my bait boat
« Reply #1 on: June 27, 2012, 05:04:27 pm »
Can you post up a couple of pictures... might help us to discover what the "grey suff" is and give a more better answer as what will remove it
john44
« Reply #2 on: June 27, 2012, 07:28:16 pm »
As essex says pictures are required for people to give advice, unless someone on the forum already owns one.
It could be a very bad Idea to (hack) at a battery.
john
armc40
  • Fall guy, it would appear !
« Reply #3 on: June 27, 2012, 07:47:23 pm »
Hate to say this...but the 'grey stuff' sounds a lot like Plastic Padding to me.....maybe contact a demolition contractor ?
Making a mistake is not a sign of weakness. Failure to admit to having made a mistake is though !
Power corrupts whilst absolute power corrupts absolutely. Imaginary power is something else entirely !
« Reply #4 on: June 27, 2012, 08:11:27 pm »
Right then 2 things i need to know as I have rebuilt a lot of these bait boats where are you located and can we please have a picture of it
Granvitas
« Reply #5 on: June 27, 2012, 10:03:17 pm »
Thanks for the replies.
I'll post up images as soon as the camera batteries are charged (batteries eh - nothing but problems!).
I live in Wiltshire - west of Swindon.
Thanks again
Pete
Perhaps you could put this location in your Profile
Moderator
« Reply #6 on: June 27, 2012, 10:27:53 pm »
Personal Message sent from a fellow Carp angler
« Reply #7 on: June 27, 2012, 10:41:09 pm »
Try a SHARP wood chisel ........slide it down the side of the batt,for goodness sake DONT go at it like abull in a china shop,be gentle,Ive seen these boats dropped on concrete etc and are pretty sturdy even though they are plastic.If this doesnt work then you will have to use a flexi shaft on a dremel with a router bit on it to chew the stuff out,second option is probably the BEST.
Batt supplier use the http://www.component-shop.co.uk/ good service and also cheap
Fixing batt back in..........No Nails......Gripfill...........Sticks like poop
Re sticking the hull back together ............Sikaflex
Page created in 0.088 seconds with 22 queries.
