OK Gents - HELP
Sorted the split, no difference, so popped the tube off and there was no pressure there at all, didn't even leak !!!
So.......Opened the end up, moved the inlet to the middle, and tried again....OK so water spurts into hull, so reconnect tube and realign into the centre of the hull.
Now bath test and I have water "dribbling through" - now please laugh if you wish as I am no expert on water cooling !! But after 5 or so mins running in the bath holding her, motor smoked as per previous and got very flipping hot.
Now, did the water cooling not work as there was no flow of the hull through the water - and it is incorrect to hold the hull ? I do know the answer to that one !! (doh)
? or was the dribble the best I am to expect ? In which case what am I doing wrong.
Nay Martin, that's a common sense approach
You'll be telling us next that he could also fine tune the system to get maximum flow using the same method.
Regards Ian
Interested to see how I can get maximum flow fine tuning ??
I will try and test on the lake over the weekend but would be interested on what everyone's thoughts are !!
CJ
