Author Topic: Which adhesive to use when applying ply skins to the bulkheads???  (Read 7196 times)
davejay
  • Member of Swindon Model Boat and Engineering Club
Hi all,
I'm getting ready to put the skins on my 1/9th scale 43ft RSL, I was going to do the scale double diagonal plank thing but have decided to do the skinning in four  seperate pieces (i.e 2 bottoms 2 sides!), I'm just wondering which is the best adhesive to use  and whether to start from the bow and work backwards or vice versa?
All input welcome
Many thanks
DAve J
Imagine a world without boats!
Its not easy, I wont try, I just wont let it happen!
Re: Which adhesive to use when applying ply skins to the bulkheads???
« Reply #1 on: June 30, 2012, 10:25:35 pm »
For wood on wood, you cannot beat PVA glue.  It will need clamping and leaving overnight but it will confidently hold it's grip.
cheers
davejay
« Reply #2 on: June 30, 2012, 10:35:14 pm »
Thanks for that Ken, I remember being told many moons ago that the slower the setting time the stronger the bond, I guess thats true with PVA, I've got EVo resin W, presume thats the best to use?
Dave J
« Reply #3 on: June 30, 2012, 10:53:18 pm »
For wood to wood I reckon you can't beat Aliphatic.
« Reply #4 on: July 01, 2012, 02:30:41 am »
I must agree with Colin here..... O0
http://www.google.com/url?sa=t&rct=j&q=polyurathane%20aliphatic%20glue&source=web&cd=1&ved=0CF4QFjAA&url=http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FPolyurethane&ei=HqnvT8SkJfGviQfXqPGuDQ&usg=AFQjCNE_rlLn4nCxgzI0hz7G2sR2UNlwQQ
Polyurathane aliphatic glue is 100%  water proof when cured & 100,000,000,000,000,000,000,000,000,000,000  times superior to PVA in damp conditions ......  :-))
Artistmike
  • North Devon
« Reply #5 on: July 01, 2012, 07:31:21 am »
Another vote for Aliphatic here, After many years of using PVA I've now moved over to it completely, as for the sort of jobs we do it's a far superior product. Just another example of the way that glue technology has moved forward I suppose.
I've just done a boat using precisely the same building technique that you're about to and it worked a treat... waterproof, tough and nicely sandable and has a similar 'feel' to PVA when you're working with it, but I like the faster grip you get .
“We don't stop playing because we grow old; we grow old because we stop playing.” George Bernard Shaw    :)
« Reply #6 on: July 01, 2012, 10:22:03 am »
I stand corrected.  I thought Aliphhatic was know as PVA.   :embarrassed:  because that's the stuff I use.
Having read Derek's treatise recommended above, I am a little wiser, but not much.   ok2
Anyway, I think you get the idea Dave J
regards
« Reply #7 on: July 01, 2012, 10:51:00 am »
PVA is now generally considered to be stuff like Evo Stik exterior wood glue which works OK but Aliphatic is a big improvement while the more expensive Super Phatic from Deluxe Materials is a sort of woodworking equivalent of superglue but still has water clean up.
« Reply #8 on: July 01, 2012, 12:30:34 pm »
How about Gorrilla glue rather messy on the hands but what a strong bond
davejay
« Reply #9 on: July 01, 2012, 06:03:30 pm »
Thanks for all the feedback guys, much appreciated.
Looks like i'll be using aliphatic, just bought a big bottle of resin w prior to posting this post, should have asked first!!!........guess I can use the resin w for coating the insides of the skins etc!!
All the best shipmates
Dave J
John W E
  • I see no ships !!
« Reply #10 on: July 01, 2012, 06:44:17 pm »
Hi ya there Dave
ResinW or Evostik exterior/pva glue will do okay for bonding the hull skin to the bulkheads, just remember - seal the exterior skin with something like a good coating of paint.  Or, for a better job - finishing Zepoxy.   I have a few hulls I have built using ResinW, PVA glue which has been about for 30-40 year and they havent fallen apart yet - YET I SAY :-) only time it does fall aprt (the model) is when it his the pond side with full belt - or dropped by Riggers :-) or hoyed in by me isnt that right Dicky. %) %)
aye
john
Knowledge begins with respect
davejay
« Reply #11 on: July 02, 2012, 12:09:28 pm »
Thanks for that John, I might as well use the evo resin w, as you say yours have been 'hoyed in' and dropped etc so i'm sure it can withstand any (if any) abuse I can give it!!!!!!
Was going to coat the exterior with sanding sealer until I get a super smooth finish then apply paint via an airbrush for hopefully a flawless finish, hope shes still about in 30-40 years time as yours are!!!!
All the best
« Reply #12 on: July 02, 2012, 02:12:07 pm »
 Where can you get Polyurathane aliphatic glue in the UK in decent size bottles?
Subculture
    • Dive-in to Model submarines
« Reply #14 on: July 02, 2012, 04:50:33 pm »
I think there is more than one type of Gorilla glue. The variety most people are dsescribing is the one which has a foaming gap filling action. This is quite different to normal Aliphatic glue which is simply a thin liquid. which penetrates the wood.
Subculture
« Reply #15 on: July 02, 2012, 05:32:24 pm »
There is Aliphatic PVA, which is usually yellow in colour, and snads nicely unlike normal PVA which tends to remain a bit chewy in my experience.
« Reply #16 on: July 02, 2012, 05:54:57 pm »
http://www.shop4glue.com/
