Hi Darren (you rang ...)
I've just measured my tank and it is 47 oz. This does over half an hour with my ASP 46, with a bit to spare on a flat lake.
Although I have changed the carb to a CMB 21 one (8.5mm bore) to give me rc mixture control, it seems to have made little difference over the standard 8.0mm bore ASP carb, either in speed or fuel used (well, maybe a bit of extra speed)
I'm not sure how it will relate to the consumption on a cat, as presumably having less drag than a deep-V should mean less fuel used.
The throttle use will also effect the consumption - if you are throttling down for corners, that would decrease fuel used too.
So if you can get the 2 x 24oz tanks in, you should have more than enough for a race - then there's just the matter of keeping it the right way up ...
Danny
