Pages: 1 2 [3]   Go Down
Author Topic: New workshop at Budgie Towers.  (Read 14315 times)
tt1
Re: New workshop at Budgie Towers.
« Reply #50 on: September 23, 2012, 03:30:32 pm »
Very smart Jon, like the stable door - excellent idea. Are they fitting guttering? especially along the back between the workshop and dividing wall, just thinking how much water may end up sitting under the workshop floor.
             Without payment I'm sure you'll eventually get exactly what you ordered. Regards, Tony.
dodgy geezer
« Reply #51 on: September 23, 2012, 04:47:47 pm »
Great minds think alike! My workshop also has a pitched roof, T+G walls, a stable door on one wall and an end door at one end. No Velux, though...  <:(
« Reply #52 on: September 24, 2012, 01:20:09 am »
Hi LB
Is your wooden workshop sitting directly on that exposed concrete base? I am just thinking about water causing you some big problems later if it is.
Sorry if that sounds a bit negative LB.
« Reply #53 on: September 24, 2012, 02:10:18 pm »
LHS and rear wall maintainence might be a problem, roof pitched from back to front and sheeted with ribbed Aluminininium roof panels would have meant a single guttering to clean out of leaves (DAMHIK) on the easy side of the roof, and a more stable covering.
   Hindsight is always a great teacher.
Liverbudgie2
« Reply #54 on: September 24, 2012, 08:44:25 pm »
It siting on tanlised (SP) supports which I'm assured is perfectly OK by numerous people.
Indeed, as is cost and noise when it rains.
LB, proud to be the key board warrior.
Stormbringer
« Reply #55 on: September 24, 2012, 11:14:17 pm »
how big is it ?
« Reply #56 on: September 25, 2012, 08:19:06 am »
So what will the first model build be LB?
Liverbudgie2
« Reply #57 on: September 25, 2012, 05:24:29 pm »
how big is it ?
20' x 9' x 8' high.
It is planned to be the Stentor (1926) followed by Machaon (1959) @1/72, then HMS Caroline @ 1/48. However there are a number of others that need to be completed namely HMS Badsworth (Sirmar Hunt) and  SCHAARHÖRN @1/25. www.schaarhoern.de/english.php
LB, Still immensely proud to be a keyboard warrior
pettyofficernick
« Reply #58 on: September 25, 2012, 05:52:35 pm »
So, it's keyboards at dawn is it....? :-) :-)
« Reply #59 on: November 19, 2012, 09:34:16 pm »
Hi LB
Is your new workshop all up and running now?
Pages: 1 2 [3]   Go Up
Page created in 0.108 seconds with 22 queries.
