Author Topic: Gear for gear box  (Read 6042 times)
A71
Gear for gear box
« on: July 11, 2012, 09:17:16 pm »
Hi
My Dad has a gear box in his multi hull ( storm 2 ) with a K and B 21 on an mod one gear box believed to be a John stidwell early type box the problem is he has striped the gear
He doesn't want to have to get a new box as its only a boat he uses on Sunday at the club
On the gear it say SHM LTD 32 DP 45T
We have looked around and can't find we're to get a new one can any body point us in the right direction ??
Here are a few pictures taken on my iPad so a bit naff
Andyn
Re: Gear for gear box
« Reply #1 on: July 11, 2012, 09:21:24 pm »
Yep that's a Stidwell box alright... Diameter of the gear, amount and pitch of teeth and dia of inner hole?
A71
« Reply #2 on: July 11, 2012, 09:36:51 pm »
Only thing I can tell you Andy is it 32 dp 45 t
Aprox diam 1/38 and in new money 34mm job to tell as there s a few gears missing  {-)
1.4 shaft hole but has been bushed down to that so has 5/16 with brass insert
Width of the gear is 1/4 overall with is 1/2 inch
Andyn
« Reply #3 on: July 11, 2012, 09:53:29 pm »
Blimey that's an odd one... I'll have a look :-))
A71
« Reply #4 on: July 11, 2012, 10:02:07 pm »
Thanks fella  :-)) we have asked Greg as well but we still can't find one
Mad_Mike
  • Lincolnshire
« Reply #5 on: July 11, 2012, 10:31:48 pm »
I think this might to the job. the first list is steel gears the second list is hard steel gears and the last is delrin gears.
http://www.hpcgears.com/newpdf/spurgears_32dp.pdf
you then go to the order form. This company can also customise the gears on request, its based in derbyshire.
A71
« Reply #6 on: July 11, 2012, 10:43:33 pm »
Think we have a winner :-) thanks MadMike at least I can get him back on the water :-)
scoop
« Reply #7 on: July 12, 2012, 09:28:42 am »
Hi John, try asking Ian S. I gave him a box full of gearboxes and delrin gears a while back, he may be able to help you out  :-))
Scoop
BMPRS Secretary/Pro www.bmprs.co.uk
PS. There ain't no going back
A71
« Reply #8 on: July 12, 2012, 11:02:23 pm »
Thanks scoop I will when I see him   :-))
Subculture
    • Dive-in to Model submarines
« Reply #9 on: July 13, 2012, 10:44:07 am »
HPC make very nice gears and other reduction components, and can supply pretty much anything you want, but be warned the price soon adds up once you factor in custom bore sizing, shipping etc.  If you do go for that option it might be worth looking at a metal or tufnol gear, which will last a long time, the extra cost over a machine cut plastic gear is quite small.
Andyn
« Reply #10 on: July 13, 2012, 06:52:08 pm »
Delrin is the way to go, the main gear is sacrificial... :-))
ids987
« Reply #11 on: July 14, 2012, 07:54:56 am »
Scoop
Speak his name and he doth appear. Are you or your Dad about in the morning ?
I've got a few "Stiddy" gears (thanks again Scoop ;)). Most are 50T, but I've got a used 45T.
ids987
« Reply #12 on: July 14, 2012, 09:05:54 am »
I think it's mostly that way cos delrin (or nylon, and some other plastics) on metal is/are what's known as "self-lubricating" - no external lubrication required. If both gears are metal, it needs constant lubrication. There were some Russian gearboxes with oil baths built into the chassis - so that the lower gear runs in an oil bath.
In a race - where you often can't hear your own engine, a sacrificial gear is often closely followed by sacrificial rod, sacrificial piston, and sacrificial liner.
Subculture
« Reply #13 on: July 14, 2012, 11:21:50 am »
If you want it self lubricating a tufnol gear will still offer that, but being a composite, and using a thermoset plastic will be a lot stronger than delrin (or any other thermoplastic).
A71
« Reply #14 on: July 14, 2012, 02:21:00 pm »
Ids we should be at the "pond " in the morning weather permitting  :}
Not sure I like the sound of sacrificial engine components lol
Thanks every one for your input  %%
Andyn
« Reply #15 on: July 14, 2012, 02:49:37 pm »
Aren't all your engines sacrificial Ian? ;)
Will be at the lake tomorrow, if it's not sloshing it down I may even bring a boat....
A66
« Reply #16 on: July 14, 2012, 03:37:19 pm »
Hi guys should i bring said box of bits in morning !? along with the new beastie ! if i can carry it to the car.
Steve
A71
« Reply #17 on: July 14, 2012, 04:50:31 pm »
WoW he knows how to use the computer aghhhhh lol
scoop
« Reply #18 on: July 14, 2012, 06:52:26 pm »
He always has done John, you just didn't know  {-) {-) {-)
Scoop
ids987
« Reply #19 on: July 14, 2012, 09:13:30 pm »
Steve
Hi Steve, I'll bring the box of gearbox bits down anyway. The 45 tooth should be almost a dead cert. I've got more of the 50 toothers, but you'd either have to raise the engine or need a smaller driver gear - which I may have amongst the same stuff. If you bring your box of bits down we could size up, but probably best start off like for like, or you'll need to be going up in prop sizes too.
A66
« Reply #20 on: July 14, 2012, 10:20:28 pm »
Thanks Ian, Infact thanks to all for your help, bit of luck i might be able to get past greg now!
Page created in 0.04 seconds with 21 queries.
