Author Topic: What is this wood supplied for planking ?  (Read 5734 times)
ukmike
« on: July 13, 2012, 07:28:45 pm »
Hello.
This is the planking supplied by Panart for the planking of my Vaporetto hull.
It would be of great help if anyone could identify it as I may need to source more of it.
Yes, I could use a substitute but it would be nice if it could be identified.
If it's of any help the sample on the left is Limewood, (Basswood), which is a soft creamy colour, the middle 4 are the supplied planks. 45 in all, they have the same smell and grain pattern
as each other but vary quite a bit in colour, from a yellow to brownish gray.
On the right are a couple of lolly sticks for comparison, I believe these are produced in huge numbers in Finland from the Pine grown there, maybe Gary, (VisuVesi) will be able to elaborate on that.
Here is the picture, let me know what you think please.
BTW the photo should have been rotated 90 degrees to the left, my error.
Mike.
Re: What is this wood supplied for planking ?
« Reply #1 on: July 13, 2012, 07:36:48 pm »
They look to light for Mahogany but they could either be Oak or Teak
Liverbudgie2
« Reply #2 on: July 13, 2012, 07:38:01 pm »
The middle two look like obechi and the outers walnut but difficult to be certain at this resolution.
LB
« Reply #3 on: July 13, 2012, 07:41:57 pm »
Right then look at this if you cant find it here then sorry Mike you are simply stuffed
http://www.dlumberyard.com/wood.html
Click on the wood samples to get the chart
« Reply #4 on: July 13, 2012, 07:42:37 pm »
Hi Mike
The planks looks like Obechi to me
aye
john
ukmike
« Reply #5 on: July 13, 2012, 07:46:10 pm »
LB
LB.
I did think of Obechi for the yellow ones but they all have a continuous grain along there lengths ( 1 Mtr ), even the grayish ones, don't think Obechi has that, also, it bends quite readily along it's length and becomes quite pliable when soaked in hot water.
Could be tho'.
Mike.
ukmike
« Reply #6 on: July 13, 2012, 07:51:07 pm »
Hmm, great link Stavros, Poplar seems to fit the bill.
But, you may be right, could be stuffed.
As a last resort I will default to using Limewood, that's Goodwood, (sic !!)
Mike.
« Reply #7 on: July 13, 2012, 08:08:59 pm »
Hi Mike
 try this top one maple, next one beech, and the bottom 3 are obechi
aye
john
ukmike
« Reply #8 on: July 13, 2012, 08:25:31 pm »
Hi Mike
aye
john
Obechi seems to be the one then John.
Looks about right, thanks, and thanks everyone who  replied.
Horrible stuff that Obechi, used to crack and split on my skinned foam wings, ( aeroplanes you know ).
Mike.
Corposant
« Reply #9 on: July 13, 2012, 08:37:50 pm »
Cornwall mention lime and walnut for the model. The paler samples don't look fine grained enough for lime, they give the impression of being a softwood - possibly spruce?
barriew
« Reply #10 on: July 14, 2012, 06:26:23 am »
Why not contact www.mantuamodel.co.uk - they are distributors of Panart models and sell a large range of strip wood. They should know what the wood is.
Barrie
« Reply #11 on: July 14, 2012, 09:49:55 am »
Obechie used to be the weapon of choice for Aerokits stringers though Manogomy seemed to rule for Billings planked offerings.
unbuiltnautilus
« Reply #12 on: July 14, 2012, 01:44:31 pm »
As mentioned previously, Mantua usually use Walnut and Lime. The Lime seems to vary from creamy white to almost green depending on batches. That would be the likely candidates for the model. as mentioned, Mantua Models in Windsor sell the timber.
deadbeat
« Reply #14 on: July 15, 2012, 01:33:30 pm »
I've built two models from this company HMS President and HMS Racehorse - good kits for the money, many hours of 'fun' planking.
Lime and Walnut are the woods used.
ukmike
« Reply #15 on: July 15, 2012, 04:23:45 pm »
Thanks guys
Definitely Obechi, sands leaving white course dust.
Had some Obichi left over from when I built model aircraft, self same stuff.
Now I can make the replacement planks that were accidentally stood on and broken.
Many thanks for all of the replies.
Mike.
