....VX Pilot
I suggest that if these are true 380 motors.........they are all built uniformly & designed to rotate in one direction only
The rotor windings are just that
The EMF when a current is applied creates an off balance force that throws the rotor in one direction either ->>>> or -<<<<
This when considered
in your case [with reverse polarity] will result in one motor drawing a higher current than the other.....and also less RPM for the same input parallel voltage
Some simple electric motors.....eg., automotive wiper motors or automotive ventilation fan motors have a thrust bearing/ball to compensate for the EMF thrust created
This is why wiper/vent fan motors run at differing speeds & current draw when reversed
So after saying this ...I like STEAM.........
