Author Topic: fail safe  (Read 4184 times)
tugs62
fail safe
« on: July 21, 2012, 10:10:49 pm »
anyone know any thing about fail safe when i plug mine in it opens the throttle up full ine tried everthing i can think of but still opens throttle ful
Re: fail safe
« Reply #1 on: July 21, 2012, 10:38:14 pm »
Sound like a programming issue with receiver set up so I'm moving you to the
radio section.
regards
ken
Re: fail safe
« Reply #2 on: July 22, 2012, 06:02:01 am »
What make/model radio is it?
tugs62
Re: fail safe
« Reply #3 on: July 22, 2012, 07:23:34 am »
its a spectum 2.4 i know it should have one built in but its fail me twice now with my boat hitting the wall
barriew
Re: fail safe
« Reply #4 on: July 22, 2012, 08:04:06 am »
Tugs
There is quite a bit of information on here about the Spektrum failsafe. How it operates, which chanell etc - do a search.  :-))
Barrie
787eng
Re: fail safe
« Reply #5 on: July 22, 2012, 08:51:55 am »
Did you re bind the receiver after you programed the radio and put your throttle stick to the center when you re bound it?
as the throttle position is remembered when the TX-RX is bound....just a thought.
Mark
unicorn
Re: fail safe
« Reply #6 on: July 22, 2012, 10:40:50 am »
  Look at the posts under Planet   T5
Quote from the little bit of paper in the latest R6M receivers...
ADDENDUM SHEET
PLANET R6M RECEIVER
IMPORTANT USER GUIDE
NEW FAILSAFE FUNCTION FOR THE R6M PLANET RECEIVER
FROM THE FACTORY SETTING (THROTTLE REVERSE SWITCH IN THE NORMAL POSITION) THE FAILSAFE IS SET TO GO TO THE LOWEST POSITION IN THE EVENT OF ANY SIGNAL LOSS. THIS FUNCTION IS NOW FACTORY PRE-SET SO NO SETTING UP IS REQUIRED.
IF YOU REQUIRE THE THROTTLE TO WORK IN THE OPPOSITE DIRECTION ( IN REVERSED ROTATION ) THIS IS NORMALLY USED WITH SOME RC BOATS OR AIRCRAFT WHEN USING A SERVO, THEN FOLLOW PROCEDURE BELOW:
MAKE SURE THE TRANSMITTER AND RECEIVER ARE SWITCHED OFF
REVERSE THE THROTTLE CHANNEL FROM THE TRANSMITTER
RE-BIND THE RECEIVER TO THE TRANSMITTER IN THE NORMAL WAY
READY TO USE
WARNING
FAILING TO RE-BIND THE TRANSMITTER TO THE RECEIVER WHEN REVERSING THE THROTTLE CHANNEL WILL RESULT IN THE THROTTLE GOING TO FULL POWER IF THE SYSTEM GOES INTO FAILSAFE
Re: fail safe
« Reply #7 on: July 22, 2012, 10:55:03 am »
Why?
He has a Spektrum
tugs62
Re: fail safe
« Reply #8 on: July 22, 2012, 01:37:35 pm »
ive tried all the above even bought a separate fail safe that plugs into the throtle channel and its the same but if i use an old 40 mhz am set it works fine
