Author Topic: servo  (Read 4910 times)
regiment
servo
« on: July 26, 2012, 01:20:57 pm »
problem with servo  my old mate has just popped in trouble with servo when the plug on the servo is moved in the rx the servo will move  but when he tries it with the tx nothing  put another tx on thinking it might be the tx but still the same could it be the socket on the rx broke  if so any body got one to sell  thanks regiment
dodgy geezer
Re: servo
« Reply #1 on: July 26, 2012, 02:09:46 pm »
Rxs are usually easy to take apart to see if the pins inside have come adrift and need re-soldering. If you want another people will have to know which Rx it is - at the least which frequency band it is.
Have you tried another known working servo on that Rx? It could be a failure in the servo plug....
armc40
  • Fall guy, it would appear !
Re: servo
« Reply #2 on: July 26, 2012, 02:49:45 pm »
Is the Rx a 27mhz...35mhz...40mhz...2.4ghz ?
Making a mistake is not a sign of weakness. Failure to admit to having made a mistake is though !
Power corrupts whilst absolute power corrupts absolutely. Imaginary power is something else entirely !
regiment
Re: servo
« Reply #3 on: July 26, 2012, 03:03:36 pm »
hello to dodgy geezer @armo 40 the tx is a 27  all i can find is beat 202 it has a battry dial on top very heavy  servo   works  ok on my boat
Re: servo
« Reply #4 on: July 26, 2012, 04:19:05 pm »
Its a 27MHz, never come across the make before, and never heard of a battery dial.
How many channels?  If 2, http://www.howesmodels.co.uk/RadioControl/viewProduct.php?ProdID=3513  seems reasonably priced if the dry joint can't be fixed.
For checking servos, Action's P22 tester is good.  For those who care to read the instructions, an invaluable tool setting up and sorting problems.
Is it your mates servo that works OK on your boat, or the radio?.
ACTion
Re: servo
« Reply #5 on: July 26, 2012, 04:56:24 pm »
Gordon
"Beat 202"?? I seem to recall these were a very, very cheap and nasty 'toy' radio churned out by one of the big-name manufacturers by the millions at Christmas time. No corners were left uncut in their production and "quality control" were words not to be uttered within a mile of the plant. I'm told the odd example still turns up at village jumble sales. Tell your mate that if he hands the radio in at the nearest police station and apologises profusely then he may get away with a caution. My advice then would be to buy a reputable make of radio from a known UK supplier and then look after it properly. As my good friend Wombat says, you can polish a 'xxxxx' all you like - but it's still just a 'xxxxx'!  ;)
DM
Artistmike
  • North Devon
Re: servo
« Reply #6 on: July 26, 2012, 05:08:21 pm »
Gordon
DM
No, don't pussy-foot about, tell it like it really is ....  {-) {-) {-)
unbuiltnautilus
Re: servo
« Reply #7 on: July 26, 2012, 06:36:53 pm »
Never one to question the knowledge of the great  ( and good ) Mr Action, god bless you sir...but the Beat 202 was a product of JR Propo, not usually known for producing Turds...polished or otherwise. On the subject, try freeze drying them, the polishing process works for a little longer, till they thaw of course ;D
regiment
Re: servo
« Reply #8 on: July 26, 2012, 06:48:55 pm »
my mates servo works ok with my radio as for the radio it is a better model than my futuba  twice the weight and a dial to show battery strengh and the Ariel is not a piece of tin rod
Re: servo
« Reply #9 on: July 26, 2012, 09:40:27 pm »
So it isn't the servo, which leaves the radio.  Whether or not it was or wasn't a quality product in days gone by, it sounds like it's broke now.  Some wetting of the dry joint, or joints seeing as it has had time for the solder to age, will add only a little to its weight, and therefore quality, and might rejuvenate it and leave it running like a new one.  Apart from the change in signal standards in the intervening years regarding channel separation.
It is always possible to add a little lead to the underside of a modern radio if it is felt that more weight will improve quality.  I have never come across a receiver with a meter fitted, nor have I ever seen one with anything other than a wire aerial, even the self supporting aerial on some boats is a plated wire.
On the subject of polished waste matter, I think that Mythbusters found that if you dehydrated it first, a good lasting polish was possible.  Whether anybody would appreciate it as a retirement memento is another question.  There is also a high probability that the engraver would decline any further jobs.
armc40
Re: servo
« Reply #10 on: July 26, 2012, 10:11:14 pm »
By all accounts.... P******d T***s are fast becoming the new retirement gift to long serving members of the military
ACTion
Re: servo
« Reply #11 on: July 26, 2012, 11:37:25 pm »
Beat 202 polished in China or Malaysia then? If more weight is required then a 12-bore usually does the job.
My old friend Bob Pyatt reckoned that his mate, who used to serve as a cook on board the Royal Yacht Britannia, had such a souvenir - apparently from the royal outflow. It was varnished and mounted in a glass case. Hopefully this wasn't kept on display in the galley.............
Wasn't Ariel a make of motorcycle?
(Ah me - too much work makes Dave a tired boy. Nighty night.)
DM
Re: servo
« Reply #12 on: July 26, 2012, 11:45:09 pm »
Dave ariel is a make of washing soap  :}
triumphjon
Re: servo
« Reply #13 on: July 27, 2012, 07:43:02 am »
long before ariel made washing powder they used to make motorcycles ! another great british marque gone to the demise of our motor manufacturing trade
Re: servo
« Reply #14 on: July 27, 2012, 09:06:33 am »
Bit of keyboard rage Malcolm?
  Mates Servo works with with radio.
  Tx has battery power indicator.
  At least that's what T'internet Exploder says.
Re: servo
« Reply #15 on: July 27, 2012, 09:22:02 am »
More of a headache resulting from a lack of full stops which help with making sense of the posting.
regiment
Re: servo
« Reply #16 on: July 27, 2012, 10:49:32 am »
oh dear no full stops and spelt aerial wrong end of the world next week i... whiter than white comes to mind just a few stops for you ......................................  now back to my problem radio and servo ok but dodgy geezer said take the back of the rx which i did and low and behold a small piece of solder and a pin fell out not being as bright as some of you lot i dumped it  but another good member armc 40 e mailed me and said he has two that i can have free so at least we have two members who do not mind missing dots as for the radio it weighs nearly 2 lbs with the battery in my posh futuba is 1 3/4 with battery  photo enclosed  O TO BE  BRAINY  REGIMENT
dodgy geezer
Re: servo
« Reply #17 on: July 27, 2012, 01:57:54 pm »
Nothing to do with being bright, otherwise I would not be able to fettle things.....  It's to do with practice. Now you have a good opportunity to practice re-soldering a pin onto an Rx board. If, as you say, you are dumping it, then it doesn't really matter if you succeed or fail - but you will get valuable experience.
Which is what life is all about....   :-)) :-)) :D
regiment
Re: servo
« Reply #18 on: July 27, 2012, 02:43:43 pm »
will try and repair as you said nothing gained   notheing lost
Page created in 0.058 seconds with 22 queries.
