Author Topic: small rigging eyes  (Read 2664 times)
logoman
small rigging eyes
« on: July 27, 2012, 11:29:45 pm »
anyone know where i can get rigging eyes that are about 6 or 7mm long?
these are bit too big:
http://www.cornwallmodelboats.co.uk/acatalog/yacht_fittings.html#aG419
Re: small rigging eyes
« Reply #1 on: July 28, 2012, 10:44:24 am »
Could you not make some.   %)
boatmadman
guitar man
« Reply #3 on: July 29, 2012, 01:51:08 pm »
Sorry to hi- jack the thread but what material would you make them out off i.e if you used say brass wire would they not tend to pull straight when tension is applied to them. I ask as I am about to require some, and it would be good to make some.
Many thanks
Regards Tony
barriew
« Reply #4 on: July 29, 2012, 02:03:57 pm »
Have you tried Modelling Timbers - he used to have lots of fittings for rigging sailing  vessels
http://www.modellingtimbers.co.uk/1.html
Barrie
boatmadman
« Reply #5 on: July 29, 2012, 02:56:01 pm »
Piano wire is best, won't straighten under load
Artistmike
  • North Devon
« Reply #6 on: July 29, 2012, 03:01:42 pm »
When you say a bit too big, how big?  What I did when I wanted them to be a bit smaller was to cut the existing ends on those ones with snips and then gently close them up a bit with pliers and voilà ! ..  :D
“We don't stop playing because we grow old; we grow old because we stop playing.” George Bernard Shaw    :)
« Reply #7 on: July 29, 2012, 03:27:03 pm »
I have used 1/4" brass split/cotter pins (google 1/4" not 6mm).
The eye of the pin is big enough for snap links to go through. It is also tough enough for sailing purposes.
Simply drill a small hole, so that the pin fits tightly, and glue in with CA. If they go go all the way through a mast/boom you can trim the ends with pliers.
The smaller brass split pins you can buy for modelling are too weak for working models.
