Hi ---- got the same prop and motor fitted to my C-11 which is based on a Captain Jan hull by Robbe --- when I first built the kit it was Kortless,
going ahead was above average and stopping was quite good but steering astern was a nightmare so I obtained a Robbe Kort from one of the bargain
bins at a show and converted C-11.
The improvements were that going ahead and towing was improved dramatically, steering astern was more than acceptable but stopping was
reduced considerably; before and after adding the Kort full astern produced a noisy cavitation -- on full size tugs with large props the Kort produces up
to 30% extra bollard pull through the Kort and Kort Pintail due to its "Aerofoil Shape",but conversely it also looses astern thrust from the aerofoil shape,
this is applicable up to approx 12 knots ahead when the Kort drag outweighs the extra thrust.
" PropShop" reccommend up to 2000 rpm for their 100 mm kort props, so doubling the rpm would be questionable -- have a look at Big Bertha`
motor change on the" udder" forum
The Robbe motor is the best low revving and high torque motor I`ve used and a real shame its been discontinued.
