Author Topic: 2.4 rec matching  (Read 4111 times)
surabaya
2.4 rec matching
« on: August 09, 2012, 10:58:15 pm »
 Just a quick question, maybe silly,.
Does the receiver for a 2.4 transmitter have to be the same make or can you mix and ma :embarrassed like the old fm / am sets ?
Re: 2.4 rec matching
« Reply #1 on: August 09, 2012, 11:03:35 pm »
OK.   A quick answer.
Yes.        This is because of their designs and operating sequences.
Hope this helps
ken
surabaya
« Reply #2 on: August 09, 2012, 11:25:20 pm »
Sure does. I was looking to buy a new 2.4 radio or 2nd hand one, but did`nt want to get stuck with cheaper one where the recievers were too expensive.
barriew
« Reply #3 on: August 10, 2012, 06:57:08 am »
Kenny is almost right - but it is possible to buy compatible receivers for both Spektrum DSM2 and Futaba.
Barrie
john s 2
« Reply #4 on: August 10, 2012, 07:36:22 pm »
Im not sure what you mean by cheap sets cost a lot for extra recs. Radio link, Planet etc all have cheap extra recs. It is the more expensive sets like Futuba that cost a lot for extra recs. Always ask before buying. John.
Subculture
    • Dive-in to Model submarines
« Reply #5 on: August 10, 2012, 09:45:42 pm »
I'm pretty sure the cheapest 2.4ghz receivers are the Orange models which are compatible with Spektrum DSM2 kit. Well under a fiver for a six channel receiver.
I use Spektrum and Corona equipment, the latter is used on retrofitted radio sets. The Corona receivers are about twice the price, but come in 4 and 8 channel versions. Still cheap at well under a tenner. I guess the price differential is only likely to be an issue of you have a ton of models to fit out.
catengineman
« Reply #6 on: August 11, 2012, 07:52:16 am »
Sorry to drop in on this thread but I have now come up with a question for those who would know
I run multi models on my 40MHz Futaba tx (all the rec) have the same Xtail freq so I can just turn on which ever model and set the transmitter to that saved settings.
So here is the question
Can I get three of my models to be on 2.4 and use the same transmitter ? would I need to 'bind' to each model each time or once the rec is bound when it is turned on it would work.
If I took three models to the lake all with 2.4 rec and my one 2.4 trans could I just run one until battery dies then turn off that model and the TX then turn on the TX and the next model, would I need to bind this model again?
I dont want to take several TX's as well as models to the lake (I only have one pair of arms)
knoby
« Reply #7 on: August 11, 2012, 07:58:00 am »
you can bind as many receivers to a 2.4 transmitter as you want. you only have to bind the receiver to the tx once, then you can swap between models just as you do with your current set up  :-))
The path of excess leads to the tower of knowledge
kinmel
« Reply #8 on: August 11, 2012, 07:59:45 am »
You can bind as many compatible 2.4 receivers as you wish to a single transmitter and with one of these programmable types, each boat can have it's own settings -
 http://www.hobbyking.com/hobbyking/store/__8992__Turnigy_9X_9Ch_Transmitter_w_Module_8ch_Receiver_Mode_2_v2_Firmware_.html
catengineman
« Reply #9 on: August 11, 2012, 08:33:54 am »
Page created in 0.013 seconds with 21 queries.
