Author Topic: how to bend a flexi shaft  (Read 3396 times)
loveboat
« on: August 14, 2012, 09:31:17 am »
im doing a project at the min and have bought a 330mm flexi shaft and outer but i need to put a bend in it ,
my question is , is there a best way to do this without nackering it up
thanks lee
Re: how to bend a flexi shaft
« Reply #1 on: August 14, 2012, 09:34:30 am »
carefully  ;D
Seriously tho what's it made from? as different techniques need to be used for different materials
loveboat
« Reply #2 on: August 14, 2012, 10:29:15 am »
Andyn
« Reply #3 on: August 14, 2012, 10:37:48 am »
Leave the shaft and ptfe liner in the tube and bend it with your hands :-))
loveboat
« Reply #4 on: August 14, 2012, 10:42:08 am »
its that simple then  :-))
cheers guys
Andyn
« Reply #5 on: August 14, 2012, 11:06:22 am »
It really is. Make sure you do leave the shaft in whenever bending the tube as otherwise you'll get kinks. Also make all bends as shallow as you can to reduce friction.
loveboat
« Reply #6 on: August 14, 2012, 12:34:56 pm »
cheers matey
Chuck Plains
« Reply #7 on: April 15, 2014, 03:33:12 pm »
Good info! Just as a plumber will use a bending spring to prevent a copper water pipe from kinking at a bend, it also prevents the internal diameter from reducing. Which is something even more necessary for a prop shaft!  O0
I'm about to try and make up a flexi shaft system for a foam flying wing. I came here looking for advice too and found LB's question helpful.
I'm not a boat builder yet, but maybe a flying boat could be on the cards.  ok2
