Made some progress on getting the boiler ready. I was given a piece of insulating fabric by muleears (thanks Cal) and I also got hold of some ceramic paper (that sounds like an oxymoron to me!) so I thought I would do a belt and braces job on the insulation. Cal's contribution (left over from his own Maccsteam 3.5" boiler) was exactly the right width for the boiler and only needed a small piece trimming off to fit perfectly. I followed the process described by logoman here
http://www.modelboatmayhem.co.uk/forum/index.php?topic=31545.msg311399#msg311399 so all the holes in both the soft stuff and the wood were cut with wad punches. I dipped the edges of the insulation in some wood dye so they wouldn't show up bright white, and fixed the first layer to the boiler with double sided tape
I did the same with the ceramic paper -
although this was held in place with ordinary tape around the outside.
I prepared my wood strips from an offcut of sapele I have had around for ages. I sliced it up on my bandsaw then ran it through my homemade thickness sander to get all the slices to a consistent thickness. Here are the slices all sanded and ready for cutting up.
I cut these to width on the bandsaw then sanded the edges to make them smooth and slightly bevelled. I did this by fixing a straight edge and a stop to a piece of kitchen worktop, then sanding the edges to give a slight bevel along the length.
You can see I scribbled on what will be the inside face so I always knew which way the bevel had been cut. I then cut the strips to length, and followed logoman's instructions to put the cladding together. Here's the top section in place on the boiler (double sided tape again).
and the whole boiler clad -
A couple of coats of thinned varnish and it's starting to look pretty good.
I need to attend to the ends - the strips are a bit long and don't all line up as I want - but I'm going to wait until I've got the bands in place before doing that. I need to confess I made a complete hash of my first attempt at the bands - one ended up wrapped round the drill chuck (I know, fix things down before drilling
) and one got cut too short (I know, measure twice...
). I am now waiting for some more banding to turn up to finish the boiler cladding off.
Ran the engine for a while today. It now has two hours on compressed air, so it should be ready for steam once I have something that can make it!
Really enjoying this
Greg
