Author Topic: my boat just sank !!!!!  (Read 2608 times)
loveboat
« on: August 15, 2012, 07:10:12 pm »
ok had a bit of a problem with my new boat .
just took it out for its first go and it didnt go to plan , the boat was swaying side to side and even fliped up in the air at one point and landed upside down , the rear of the boat started to sink until it got to the front of the boat and stopped and started bobbing up and down like a fishing float .
any ideas why it was so unstable swaying side to side and flipping up ???
cheers chaps
Re: my boat just sank !!!!!
« Reply #1 on: August 15, 2012, 07:21:17 pm »
which one was it?
loveboat
« Reply #2 on: August 15, 2012, 07:23:48 pm »
the silver one mate
loveboat
« Reply #3 on: August 15, 2012, 09:18:10 pm »
can anyone shed any light on this as ive not got a clue
Mad_Mike
  • Lincolnshire
« Reply #4 on: August 15, 2012, 10:20:59 pm »
have you modified it in anyway?
loveboat
« Reply #5 on: August 15, 2012, 11:26:57 pm »
no mate its brand new , only thing i did was use a 3000mah lipo instead of the 2200mah recomended
Stormbringer
« Reply #6 on: August 15, 2012, 11:29:01 pm »
possibly the extra weight unballanced it
it may be as simple as moving the battery forward or backwards to get the ballance right
loveboat
« Reply #7 on: August 15, 2012, 11:46:13 pm »
ill have a play about with the battery tomoz see if that sorts it , cheers buddy
hmsantrim
« Reply #8 on: August 16, 2012, 03:32:00 am »
 Hi Love boat.
                    RE: any ideas why it was so unstable swaying side to side and flipping up ???  Looks like you have overpowered the hull you have gone to fast and there is not enough
                     hull in the water to maintain stability at the speed your going at. Would suggest try easing back on the stick a bit see what happens.
                    Also look at the battery position is it lying flat in the hull in the lowest position it can be inside the hull.  If the battery is vertical or high up this can also cause Rock n roll in
                   the boat at speed.  if you have flipped the boat deff overpowered it for that to happen, too much air under the hull.  If you look at some of the powerboat race crashes on
                   you tube most of them go vertical first.
                                cheers Frank.
scoop
« Reply #9 on: August 16, 2012, 09:19:57 am »
The centre of gravity balance point should be 27 to 30% measured from the transom (most people settle for 30%) eg if your boat measures 36 inches the c of g will be 12 inches from the transom, and as someone else has already said keep all the weighty gubbins as low in the boat as possible.
Scoop
ps It may help to put some foam inside the boat to help with floatation should it flip again. I use the foam swimming noodles, easy to cut to shape and stick in with a bit of silicon sealant, don't let the foam get too close to the motor/esc.
BMPRS Secretary/Pro www.bmprs.co.uk
PS. There ain't no going back
Page created in 0.103 seconds with 22 queries.
