Thanks Mates, An update:
Thought I better stop buying boat models and actually work on one for a change …
The chemicals for aging the brass: " blacken it" is the trade name.
Using some old wood stain that was lyin about to "age" the wood.
Details on the cabin are coming together, inner and outer trim pieces are mostly done, not sure if I am gonna paint or stain the outer part of the bridge.
"Windows" are cut and shaped but wont go in till later.
The first layer of the bridge roof is on, needs trimming to shape after the Z-poxy has set up ( this is Not the final shape ).
Ships wheel and control console done, put down some floor grating where the pilot would stand to keep boots dry.
Steerage access and engine access hatches have had lift/lock rings put on, they are brass etched parts.
Put some weathered brass bolts in the rub rails to show where they would be secured to the hull.
Portholes are mounted but no "glass" yet as a a coat of matte spray may be applied after final weathering is done.
Getting there, though a long way to go.
