I have applied 3 coats of sanding sealer in readiness for the glass fibre cloth and resin which will
be going on tomorrow.
Nordlys...
Hi Nordlys,
I haven't followed your work on the hull closely, or I would have reacted sooner, but I think that the sanding sealer may have been (part of) the reason the glasscloth didn't go on the hull without wrinkles.
Granted, for a first attempt, you did well.
I always put the glasscloth on the bare hull, no sanding sealer or whatever, just a light coat of epoxy resin, of which most is absorbed by the wood (acting as a sanding sealer, correct), but as it's epoxy, when adding the glasscloth, or a second layer within 24h, you have the benefit of the chemical bond between the two layers.
I'm not sure the epoxy will have adhered to the sanding sealer just as vigorously, leaving room for imperfections in the layer...
Nice red by the way!
Regards, Jan.
