Author Topic: Brass etching primer  (Read 7397 times)
Popeye
  • I see no ships!
« on: September 03, 2012, 11:17:36 pm »
Can anyone recommend an etching primer for use on brass which can be oversprayed successfully with Halfords'  etc., acrylic spray paints?
Brush applied primer would be preferable - lots of small fitments to treat at different stages of model construction - failing which spray can application would have to suffice.
Thanks in anticipation of any positive responses.
Confucius he say, 'if all else fails.......reach for the  Red Top-Stop'.
Re: Brass etching primer
« Reply #1 on: September 03, 2012, 11:31:32 pm »
pettyofficernick
« Reply #2 on: September 04, 2012, 12:17:55 am »
Hi there, This is pretty good stuff, I have just used it to prime my TVR1A steam engine, gives a nice dense coat on which to paint.
http://www.ebay.co.uk/itm/Primer-Beige-Bare-Metal-Primer-Aerosol-High-Build-Acid-8-Times-Faster-Dry-Etch-/180958358108?pt=UK_Body_Shop_Supplies_Paint&hash=item2a21f56a5c
Nick. :-)) :-)) :-))
« Reply #3 on: September 04, 2012, 01:07:06 am »
Baisically same stuff but a lot cheaper and from a good ebayer as welll
unbuiltnautilus
« Reply #4 on: September 04, 2012, 01:12:58 pm »
Halfords sell an ACID etch primer which would do the job for you
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_170745_langId_-1_categoryId_165625
Good stuff, have used it on the nylon components of the rotor head on a RC Helicopter prior to painting a metallic effect onto it. It stuck to that so should work on most materials..
« Reply #5 on: September 25, 2012, 11:02:21 am »
The U-Pol Acid 8 stuff works great on brass components, does stink a bit tho
Also you guys are lucky... the same stuff was €33 a can here in finland
Subculture
    • Dive-in to Model submarines
« Reply #6 on: September 25, 2012, 12:50:32 pm »
You can purchase etch primer in cans for brush painting. However if this is just for small components, I just dip them in some ferric chloride (PCB etchant) for a little while, wash them off, then prime them with any conventional primer, and that works fine. The etchant does the same thing by roughening the surface with milions of microscopic pits, providing something for the paint to grip onto.
You can purchase ferric chloride in Maplins or from Rapid online.
mrsgoggins
« Reply #7 on: September 26, 2012, 08:00:32 am »
Precision Paints single pack primer works OK for me but has a limited shelf life which is a pain when you only use small amounts. I shall note the info given on this thread.
Page created in 0.423 seconds with 21 queries.
