Author Topic: Club 500  (Read 1407 times)
davidsg1a
Club 500
« on: September 08, 2012, 10:07:50 AM »
Hello everybody
Im just wandering what sero and battery people are using in there club 500s, at my club in Glasgow there is 9 of us going to build them and we want to know what every body else is using in them.
Look forward the hearing your wisdom. :-))
David
red181
Re: Club 500
« Reply #1 on: September 08, 2012, 12:26:04 PM »
if you are going to race as per the standard rules, then the only battery permissable is a 7.4v nimhs pack. If you are going to just mess around, then anything!
Servo, I use a small micro servo, to save weight! we are a very competitive bunch that race at St Helens Model Boat club! weight is the enemy with these boats :-))
http://www.ebay.co.uk/itm/HXT-9g-micro-servo-x4-RESIN-gears-futaba-Hitec-UK-stock-/150872054125?pt=UK_ToysGames_RadioControlled_JN&hash=item2320acd96d
http://www.sthelensmodelboatclub.co.uk/
TheLongBuild
  • Build em, and play hard..
Re: Club 500
« Reply #2 on: September 08, 2012, 04:29:31 PM »
Well they certainly park their 500 hundreds pretty well, at least Duracell does !! :} :}  Inter Club soon  :-))
Also no extra weight, trims etc if your racing
Re: Club 500
« Reply #3 on: September 08, 2012, 05:51:11 PM »
Searching suppliers of 7.4 v NiMH.
All I can find are 7.2 v   :}
Tug-Kenny
Re: Club 500
« Reply #4 on: September 08, 2012, 10:00:13 PM »
That's because these batteries contain 1.2 volt cells.     8)
Tug-Kenny
Re: Club 500
« Reply #5 on: September 08, 2012, 10:01:55 PM »
Just had a thought  (dangerous yes I know)  When the 7.2 volt are charged they can go up to 8.4 volts    :}
davidsg1a
Re: Club 500
« Reply #6 on: September 09, 2012, 08:12:28 PM »
Thanks for the info, is there any rules on the amps of the battery?
David
Tug-Kenny
Re: Club 500
« Reply #7 on: September 09, 2012, 08:21:02 PM »
Yes, it's a number followed by mAh   (milli amps per hour)
For example 1000mAH  is 1 amp for one hours running. You can see by this the amount of time you can expect the motor to run.
Hope this helps
Re: Club 500
« Reply #8 on: September 09, 2012, 08:23:48 PM »
You are still stuck with 6 cells, and the battery saying 7.2 volts on the label.  I don't recall anybody mentioning an A/H limit, but generally, for a given size, the higher the A/H, the heavier the battery.
