Author Topic: Ceramic burner  (Read 5692 times)
steam up
Ceramic burner
« on: September 13, 2012, 11:35:17 pm »
Hi folks working on a burner and I am looking to seal the ceramic disc to the unit can anybody recommend a suitable silicon sealant and the retailer I can obtain it from?
Thanks Mark
ooyah/2
Re: Ceramic burner
« Reply #1 on: September 13, 2012, 11:41:38 pm »
Thanks Mark
Mark,
Try Gun Gum exhaust sealant from Auto shop, I have found it successful in the past.
George.
pettyofficernick
Re: Ceramic burner
« Reply #2 on: September 14, 2012, 12:01:46 am »
Hi There, the ceramic part of my Maccsteam burners seems to be pressed into the housing, a bit like cutting a biscuit out, there does not appear to be any form of sealant or adhesive holding it in place....
Nick :-) :-) :-)
Re: Ceramic burner
« Reply #3 on: September 14, 2012, 07:42:21 am »
Nick :-) :-) :-)
My BIX burner looks to have the sides folded over the ceramic parts on the edges by about 2mm
Granted its for a traction engine and not a boat but its the same thing
steam up
Re: Ceramic burner
« Reply #4 on: September 14, 2012, 09:43:41 am »
Thanks for the rapid response.
Mark
kiwimodeller
Re: Ceramic burner
« Reply #5 on: September 14, 2012, 11:19:32 am »
Another way to hold the ceramic in place is to just drill a small hole on each side of the casing and put a piece of stainless wire across the front of it. Cheers, Ian.
steam up
Re: Ceramic burner
« Reply #6 on: September 15, 2012, 09:18:34 am »
I have built in a ledge within the burner to support the ceramic disc I was thinking more in terms of sealing the edge of the burner.
Thanks for the feedback.
Mark
ooyah/2
Re: Ceramic burner
« Reply #7 on: September 15, 2012, 03:01:09 pm »
Mark
Mark,
Here are some pics of ceramic burners that I have made in the past with GUN GUM paste as used in car exhaust repairs.
 Like you I built in a small angle ledge to support the ceramic slab  but the flame spilled up thro" the edges but the paste cured that, once fired up it lasts for ever, in both cases silver solder was used.
George.
This one was made using a piece of 2" x 2" square brass tube.
This one was made up for a Yarrow boiler from various bits of brass plate and was 5" x 2"  again with ledge angles and cross bars to support the ceramic slab.
Hope this helps.
steam up
Re: Ceramic burner
« Reply #8 on: September 15, 2012, 09:08:56 pm »
Just finished is this what I'm looking for?
What are the clamed advantages of ceramic burners by the way?
Mark
KNO3
Re: Ceramic burner
« Reply #9 on: September 19, 2012, 11:54:43 am »
Ceramic burners are supposed to have the advantage of heating the boiler, besides through the hot combustion products, also through direct radiant heat ( because the ceramic glows and radiates heat - that's the non-scientific explanation).
In my experience this can be an advantage in boilers where a large heating surface can be very close to the ceramic burner: horizontal boilers heated from underneath, vertical boilers with a wider surface directly over the burner etc.
For boilers of the centre flue design (vertical or horizontal) I think the benefits of a ceramic burner can't really be noticed (since only a small heating surface is in direct proximity to the burner, to receive the radiant heat) and you can use a torch type burner with the same or perhaps even better results.
steam up
Re: Ceramic burner
« Reply #10 on: September 19, 2012, 03:44:01 pm »
Thanks for the response  :-) the boiler is a vertical one currently set up with a camping burner.
KNO3
Re: Ceramic burner
« Reply #11 on: September 19, 2012, 08:54:33 pm »
Then a ceramic burner should work very well, better than a camping burner.
Page created in 0.504 seconds with 17 queries.
