Author Topic: Magnetic On-/Off-Switch  (Read 1701 times)
Gopher
« on: October 06, 2012, 06:24:16 PM »
Has anyone heard of these and if so where can I aquire one from, it would save me having to take the top off my tug
grasshopper
    • A1 Hobbies Ltd.
Re: Magnetic On-/Off-Switch
« Reply #1 on: October 06, 2012, 06:33:39 PM »
What you're looking for would be a reed switch, a glass enclosed, magnet actuated switch you can fit under the deck or similar and place a magnet nearby and it'll switch your system on. Something like this might do it.....
http://uk.farnell.com/hamlin/drr-129/reed-switch-no-400vdc-3a-100w/dp/4332337
Another alternative would be to use a rotary switch disguised as a deck fitting, like a bollard.
flashtwo
« Reply #2 on: October 06, 2012, 06:44:34 PM »
You made need the reed relay to operate a higher current auxilliary relay, if your tug motors pull more than 3 amps.
Ian.
grasshopper
    • A1 Hobbies Ltd.
« Reply #3 on: October 06, 2012, 06:56:37 PM »
Most people would only use the reed switch to control the radio system, 3 amps would be ample. The motors should be switched by your ESC/s and not affect the reed switch rating, but using a relay would be advisable is you wire it as Flash has suggested.
Subculture
    • Dive-in to Model submarines
« Reply #4 on: October 07, 2012, 08:27:50 AM »
You can purchase ready-made magnetic switches from Engel. They sell them for model submarines but they are little bit expensive. You can make a simple one yourself using a pair of reed switches and a bistable relay. The cost is likely to be no more than about 5-10.
Gopher
« Reply #5 on: October 07, 2012, 05:14:15 PM »
Thank you all for your replies, being a very new newbie to the hobby I think I will stay with the switch until I have a lot more experience and knowledge, I ant arf gorra lot of learning to do
