Author Topic: help required  (Read 2922 times)
Hover Tim
help required
« on: October 09, 2012, 06:46:36 pm »
a frinf of mine wants to build a lagre scale Pindair Skima 4 hovercraft the full size craft has an inflateable ring round it to ensure the craft is safe on the water my mate wants to replicate this on his model but is not sure how to do it any ideas
vid of the craft in action can be seen here http://www.youtube.com/watch?v=0FJ58iZU1oo
john s 2
Re: help required
« Reply #1 on: October 09, 2012, 08:47:32 pm »
Possibly layflat hosing which is sold in various sizes would do? This could be foam filled? John.
john44
Re: help required
« Reply #2 on: October 09, 2012, 08:53:39 pm »
A chap in our club uses a bicycle inner tube.
john
richald
  • Retired and loving it!
Re: help required
« Reply #3 on: October 09, 2012, 08:54:39 pm »
The 'inflatable ring' you refer to is in fact a skirt that is inflated when the craft starts
to hover - it is pumped up either by the thrust fan as in the Skima four in your video or
by a separate lift fan. (look at 4:28 in the video you can see the skirt deflated, and at 5:07-5:09
you can see it inflate as the skima starts to hover....)
I'm currently building a hovercraft model
- have a look at the pix at ....
https://picasaweb.google.com/104738298347389224405/HovercraftProject
The skirt inflation and lift function will be carried out by a brushless motor and 6" x 5" propeller
Before you ask, I blew up the 65mm ducted fan unit  :embarrassed:
At the moment I am cutting out the skirt panels from black polyester lining material, the
joints will be made using copydex latex glue - I have some sample joints I made to test the
system. The skirt will be made airproof using copydex diluted 50:50 with water.
Let me know if you wish to know more.
A few links ....
http://www.model-hovercraft.com/index.html
http://www.brocki.neostrada.pl/hovercraft/frames_e.htm
https://picasaweb.google.com/100969545134162459328/Griffon2000TD
Richard
Senior member of the OGG (Order of the Grumpy Gits)
Membership Number : 002
Hover Tim
Re: help required
« Reply #4 on: October 09, 2012, 09:40:45 pm »
is is an inflatebae tube that not inflated by the fan trust me i have infalted some of the craft before the idea is the the inflateabe section keeps the craft foating when on the water if you watch the video you will see them put the craft together and pumping the hull up with air.there is then a skirt attched to this
your griffon looks good this is mine
richald
Re: help required
« Reply #5 on: October 09, 2012, 11:06:19 pm »
Tim,  I am guessing from your reply you are referring to an internal
tube which is actually part of the hull - something like the side tubes in a rib?
in which case john44's idea of a bike inner tube is a good one provided it isn't too heavy
You could also make a 'solid' tube out of gray plumbing pipe insulation
(sealed if it's not a closed cell foam)
Never mind my Griffon looking good! - if it turns out as good looking as yours I'll be well happy!
what did you use for your skirt material ? (this is probably the first of many questions mate!)
Richard
Hover Tim
Re: help required
« Reply #6 on: October 10, 2012, 06:31:29 pm »
yep likea rib is the best way to describe it i will pass on the info as for my skirt is a tent liner avalible from http://www.modelhovercraft.co.uk/ just drop them an email or if you want you can buy a ready meade skirt from them it just need to be stuck on this is my model at a recent show http://www.youtube.com/user/ModelHoverAssoc?feature=CAQQwRs%3D
Page created in 0.097 seconds with 21 queries.
