Author Topic: Twin Screw Liverpool class lifeboat  (Read 13061 times)
gribeauval
Re: Twin Screw Liverpool class lifeboat
« Reply #25 on: November 16, 2012, 08:13:59 pm »
Time to get the straight jacket ready!!
The calico layer is now hardened and the top planking started. Each plank is carefully shaped and joggled into the king plank avoiding getting glue on the outer surface.
Each plank is also fastened with small brass nails to represent the copper ship nails used on the full size item. The nails will all be punched down and filled when the varnishing is done. This will produce the 'spotty' appearance normally seen on the full size canopy. When removed from the moulds all the nails inside will be cut off flush to simulate the pattern of roves seen on the inside.
True Lifeboat Nutter!!
« Reply #26 on: November 16, 2012, 09:00:28 pm »
Beautiful work there Mike.........mind you matey.........it's easier with paper!! {-) {-) {-) {-) {-) {-) :embarrassed: :embarrassed: :embarrassed: :embarrassed: :embarrassed: :embarrassed: :embarrassed: :embarrassed:
Page created in 0.013 seconds with 17 queries.
