Hi guys just after some info
Ive been an aero modeller for about 5 year now and done a couple of scratch builds and just recentley decided i want to get into boats due to not getting out much with the distance i have to travel etc
Ive just ordered the Orca plans of Pat trittle and trying to get my head around the power system to be used:confused:
Ive got loads of spare motors and esc of my planes (the exact ones) and just want to ask if i could get away with using them in a boat my system sofar consists of
Jr propo pcm9x tx with frsky 2.4ghz module (of my planes)
2x 3s 5000mah 20c lipos
A2217-6T 1500kv 250watt motor which is a replacement for a 400/480 size motor
Motor Specs:
* Type: A2217-6
* No. Of cells: 2-3S LiPo/8-10 Ni-xx
* RPM/V: 1500KV
* Max. efficiency: 79 percent
* No load current @10 V: 1.0A
* Working current: 22-26A
* Max Current capacity: 28A (60 seconds)
* Dimensions: D28 x L35mm
* Shaft diameter: 4mm
* Weight: 72g/2.51oz
30 amp esc
Specification:
* Class: Brushless
* Model: 30A Pro
* Application: Aircraft
* Constant Current: 30A
* Burst Current: 40A (for 10 seconds)
* BEC Mode: Linear
* BEC Output: 5V/2A
* BEC Output Capability:
on 2S LiPo - RX + 5 standard micro servos,
on 3S LiPo - RX + 4 standard micro servos,
on 4S LiPo - RX + 3 standard micro servos
* Battery Cell Count / Input Voltage: 2-4S (7.4V - 14.8V) LiPo or 5-12 (6V - 14.4V) NiMH
* Weight: 25.8g
* Dimensions L*W*H mm: 55 x 25 x 9mm
any info and assitance would be greatly appreciated
Thanks Les
