Here's a slightly clearer picture which I didn't know I had
I have used round doweling, filed and sanded to the shape of the blocks. I then work on the end of the dowel, shaping it till it is right, including putting the groove on. When done, I cut the block off the end and shape the other side. Hope this makes sense.....
Mr Ski, it makes perfect sense, yes, but I think I need something more functional that what you have described. For starters, don't you end up with the grain through the width of the block? Thanks though.
I think I remember seeing kits at either The Model Dockyard, or that chap in Clevedon's (George Turner??) websites.
Well, Pussycat, you may be right but I can't see them. I find that Model Dockyard and Conrwall Model Boats (etc etc) all have web pages where the fittings are listed by manufacturer rather than nature...which makes it nigh on impossible to browse for a particular fitting.
I've got a book on scale model sailing boats that shows a very nice block kit from a company which seems to have evaporated since it was published.
You might be able to file off part of a Pekabe block with becket to achieve the look you want. Or maybe kit bash one to get the strap on the inside.
I don't know how much Pakabe fittings cost in the middle of Land Locked US of A but over here I'd have to remortgage the house to afford them. They're very nice and there are some which come close to what I want but not affordably in the number required for a gaff cutter.
I can see that I might have to try making some for myself. From the photo above you can see that there is a long "U" metal strap embedded in the wooden block. I'm sure I could bend some of these from brass and whittle the wooden cheeks. Then the sheaves can be had from
RBModels (or some such...although I'm quite liking RB right now).
Having said which, RBModel also do some rather nice wooden blocks: see
HERE. I did order a few the last time I got other stuff and they're very nice. I might experiment to see if the metal strapping can be inserted sufficiently securely.
Watch this space...........
