Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14   Go Down
Author Topic: Name the Part - 2  (Read 75282 times)
grendel
Re: Name the Part - 2
« Reply #175 on: December 01, 2012, 09:11:19 pm »
Great Britain?
pettyofficernick
« Reply #176 on: December 01, 2012, 09:12:02 pm »
Alas no.....
grendel
« Reply #177 on: December 01, 2012, 09:16:01 pm »
hydraulic pump?
pettyofficernick
« Reply #178 on: December 01, 2012, 09:17:44 pm »
Nah..... ;) ;) ;)
grendel
« Reply #179 on: December 01, 2012, 09:18:48 pm »
hydraulic steering gear
pettyofficernick
« Reply #180 on: December 01, 2012, 09:28:57 pm »
getting colder and colder all the time.... {:-{ {:-{ {:-{
« Reply #181 on: December 01, 2012, 10:07:10 pm »
Hullo Nick.......
1. is it a French designed assembly?...............
2. is it used in a Naval application? ............... ;)  ....Derek
pettyofficernick
« Reply #182 on: December 01, 2012, 10:28:08 pm »
Good evening Derek, no, not French. Not military type naval, more for passengers.....after vessel name as well as machine, think historic :-)) :-)) :-))
« Reply #183 on: December 01, 2012, 10:40:31 pm »
mmmmmmmmmmmm lets asume it is atmospheric & pneumatic & we consider one side only...so it could be using the diameter ratios of d:e to perform work
1. if the wheel is rotated clockwise the right side chain A is lowered, the right side piston plate d
2. this then forces the air a down and throught the righthand side plate check valve
3. however as this air a passes further down it closes the plate check valve @ i & stops the air from entering to the annulus side of the smaller piston
4. the above seems non functional
5. if the pipe attachments l were drawn differently and allowed higher pressure air to be admitted to the top of the smaller piston e this could work, however some of the plate check valves would also cause non functionality ............ >>:-( ....Derek
Jerry C
« Reply #184 on: December 01, 2012, 10:42:52 pm »
Stabiliser actuator?
pettyofficernick
« Reply #185 on: December 01, 2012, 10:48:29 pm »
Not hydraulic.... :-) :-) :-)
Jerry C
« Reply #186 on: December 01, 2012, 10:54:45 pm »
Punkah  wallah drive?
pettyofficernick
« Reply #187 on: December 01, 2012, 11:38:18 pm »
Think along the lines of a ratchet.....
polaris
« Reply #188 on: December 03, 2012, 07:30:08 pm »
... re the outstanding, a further clue...
polaris
« Reply #189 on: December 03, 2012, 07:31:29 pm »
... this one might be a touch too difficult? :-)
pettyofficernick
« Reply #190 on: December 03, 2012, 07:43:15 pm »
Perhaps a device for testing rock samples? I notice just below the handle, there appears a sort of glass tube containing granules of some sort.....
polaris
« Reply #191 on: December 03, 2012, 07:52:01 pm »
Dear Nick,
Sorry no. It is an RN part!
Regards, Bernard
« Reply #192 on: December 03, 2012, 08:13:33 pm »
Wire swaging machine?
pettyofficernick
« Reply #193 on: December 03, 2012, 08:42:49 pm »
Air start handle and valve for Paxman DG set :-)) :-)) :-))
polaris
« Reply #194 on: December 04, 2012, 12:59:36 pm »
Sorry, no. A clue maybe :-))
boneash
  • In an actual war zone there are 2 types of ships,
« Reply #195 on: December 04, 2012, 04:04:07 pm »
dowty = hydraulics, oleo legs
boulton paul = gun and missile turrets
therefore my guess is a hydraulic turret rotate valve..
pettyofficernick
« Reply #196 on: December 04, 2012, 04:14:44 pm »
Harrier fuel control system part or undercarrige retract lever.....
« Reply #197 on: December 04, 2012, 04:25:40 pm »
Periscope control
polaris
« Reply #198 on: December 04, 2012, 06:38:31 pm »
Dear Boneash,
You are sort of getting warmer O0
Regards, Bernad
p.s. My double entry was an experiment, so please don't forget Nicks' item. B.
pettyofficernick
« Reply #199 on: December 04, 2012, 06:49:46 pm »
Torpedo tube venting valve control?
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14   Go Up
