Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14   Go Down
Author Topic: Name the Part - 2  (Read 71220 times)
grendel
Re: Name the Part - 2
« Reply #275 on: December 14, 2012, 10:51:59 pm »
lubrication pump
pettyofficernick
« Reply #276 on: December 14, 2012, 10:53:07 pm »
We seem to be going through all the systems here, not a lub pump.......
polaris
« Reply #277 on: December 14, 2012, 10:53:11 pm »
... might well be... nice looking beasty! :-))
pettyofficernick
« Reply #278 on: December 14, 2012, 10:54:26 pm »
... me done for!!! {-)
Oh Bernard, don't chuck the towel in just yet. :-) :-) :-)
grendel
« Reply #279 on: December 14, 2012, 10:54:58 pm »
bilge pump
polaris
« Reply #280 on: December 14, 2012, 10:55:49 pm »
Oh yes I am, I going to be bed and that's that!!!!!!!!! Will leave you night owls to it!!!!!! O0 {-)
grendel
« Reply #281 on: December 14, 2012, 10:58:20 pm »
hydraulic pump
pettyofficernick
« Reply #282 on: December 14, 2012, 10:59:16 pm »
Ah, could be used as such, this type of pump has many uses, I am after the type of pump, ie centrifugal, diaphragm piston etc. Yes, they are used as bilge pumps, but not what I had in mind, other stuff needs pumping on board ships.... :-) :-) :-)
pettyofficernick
« Reply #283 on: December 14, 2012, 10:59:54 pm »
grendel
« Reply #284 on: December 14, 2012, 11:07:22 pm »
well looking at that side cover I would say it has valves and must be a piston type pump.
could be for water - fresh water maybe.
grendel
« Reply #285 on: December 14, 2012, 11:09:56 pm »
radial piston?
pettyofficernick
« Reply #286 on: December 14, 2012, 11:15:10 pm »
'Fraid not, they work in quite a novel fashion..... %) %) %)
« Reply #287 on: December 14, 2012, 11:21:44 pm »
Regenerative Turbine Pump ??
aye
john
« Reply #288 on: December 15, 2012, 12:32:15 am »
poo....it is a sanitary pump........ {-) ...the open casing side door is easily removed to clear blockages..... :embarrassed: women can be the main offenders disposing of unmentionables.....  >>:-(
Models include centrifugal and rotor lobe .......the latter being positave displacement..........
However with the input shaft being on axis I suspect a centrifugal ...unless it is a single rotor x twin lobe...... %) .......Derek
pettyofficernick
« Reply #289 on: December 15, 2012, 01:03:09 am »
Derek, you are nearest so far, yes, they are used to shift sewage, and anything else sludgy, (even used to shift jam around the jam factory) Yes, positive diaplacment, self priming, very efficient. Now, it all depends on what you mean by rotor lobe pump......
« Reply #290 on: December 15, 2012, 01:13:42 am »
Nick...I fully understand that a sanitary pump is by definition capable of being cleaned to Health Department standards for processing of foods for human comsumption
However the style you have shown is the easy clear blockage style......
Lobe rotor pumps come in many styles.........an example follows......
The blue hammer tone paint also gives the actual manufacturer away....Servex?...........Derek
pettyofficernick
« Reply #291 on: December 15, 2012, 01:19:15 am »
The removable front is not primarily there to clear blockages, it is to allow  replacement of the wearable parts within and for adjustment purposes. It is not a lobe rotor pump, but you are very close, as both types are made by the same manufacturer, a name synonymous with this type of pump.
« Reply #292 on: December 15, 2012, 01:20:35 am »
 %)  .....Jabsco?
pettyofficernick
« Reply #293 on: December 15, 2012, 01:26:58 am »
Totally different type of pump. Re the removable cover, it is sealed with 2 gaskets, one can be removed to compensate for wear.
« Reply #294 on: December 15, 2012, 01:32:14 am »
OK ...Jabsco was a silly thought :embarrassed: ...sorry ....how about helical rotor?.......a smooth stainless helical screw rotor inside a rubber stator ...alah MonoPumps?......
pettyofficernick
« Reply #295 on: December 15, 2012, 01:41:36 am »
Getting colder nowyou will have come across these, you would find something very similar to this if you took a peek behind the cover....
« Reply #296 on: December 15, 2012, 02:12:09 am »
OK....how about a centrfugal macerator pump  :((
pettyofficernick
« Reply #297 on: December 15, 2012, 02:20:21 am »
Not centrifugal, quite the opposite really. If you look carefully at the picture if the 'innards' i have just posted, you will notise that the steel shaft has a number of eccentric lobes on it, these are a tight-ish fit in the 3 rubber bits that have holes underneath. When the shaft rotates, it causes the rubber 'bits' undulate.....I must now retire to bed, so I shall bid you goodnight sir.......
« Reply #298 on: December 15, 2012, 02:24:10 am »
 :}  progressive cavity pump?  :((
pettyofficernick
« Reply #299 on: December 15, 2012, 08:43:45 am »
Not a progressive cavity pump........
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14   Go Up
Page created in 0.166 seconds with 17 queries.
