Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14   Go Down
Author Topic: Name the Part - 2  (Read 54364 times)
Re: Name the Part - 2
« Reply #300 on: December 15, 2012, 09:32:52 pm »
Still wondering what a flugel pump is? Is it for blowing the flugelhorn?  ;D
« Reply #301 on: December 15, 2012, 11:48:51 pm »
Just a guess Noresman.......... O0 .....Derek
http://www.flugel-llc.com/products.php
grendel
« Reply #302 on: December 16, 2012, 01:37:57 pm »
just a name picked at random from the recesses of my brain.
ie a guess.
Grendel
« Reply #303 on: December 16, 2012, 02:28:07 pm »
Cam pump of some sort?
pettyofficernick
« Reply #304 on: December 16, 2012, 03:48:43 pm »
Eccentrics rather than cams, look carefully at the clue picture of the working parts, a shaft, with 3 eccentrics, and 3 tight fitting rubber things, ( I say things because if I said what they are, it would give the game away) The eccentrics create a negative pressure inside the rubber bits, at the same time sliding them over a series of holes in a port block. The reason for ther e beins multiple eccentrics etc is to ensure a continuous flow, rather than an intermittent ont.....
polaris
« Reply #305 on: December 16, 2012, 04:24:49 pm »
Dear Nick,
The only thing I have in the Stores at the moment that looks remotely like this is a 7hp compressed air motor fixed on a bed to a hydraulic pump. It came off a twin boom drilling rig I bought for for very little some centuries ago(!), from the Redburn Mine only a matter of days before the pumps were switched off - I think this about 1976. With the help of the Workshop crew, and a number of ten pound notes(!), and the normal good natured swearing(!), we took the booms off, and everything else quickly salvageable, but the rest of this poor tracked machine lies 500ft under water now in the main drive. What a job to squeeze those booms into the cage! I have the p.graphs! What annoyed the Crew was that someone had not charged up the remaining 3t battery loco, so we had to push everything about a mile on six flatbeds! Wonderful days never to be repeated.
So, after this preamble, is this very nice shiny piece of eqpt. of yours connected with compressed air?
Kind Regards, Bernard
pettyofficernick
« Reply #306 on: December 16, 2012, 04:36:28 pm »
No Bernard, unfortunately not, driven by electric motorn either directly or by chain/belt. Sone portable versions can be driven by a diesel engine. Another, if obscure clue....Think 1960's Sci Fi B movies / comics, think of the names given  to robots etc, eg Tobor the Great. The name of the manufacturer sounds like something out of one of those. Is it time, do you think, for me to reveal the answer to the unanswered poser from earlier? :-)) :-)) :-))
Nick.
pettyofficernick
« Reply #307 on: December 16, 2012, 04:51:16 pm »
Right you are Bernard. The answers to both are all to be found within the pages of the internet, just a little research will reveal all. %) %) %)
pettyofficernick
« Reply #308 on: December 16, 2012, 05:07:04 pm »
The blue hammer tone paint also gives the actual manufacturer away....Servex?...........Derek
Not Servex, sorry, missed that line when I originally read your post
pettyofficernick
« Reply #309 on: December 16, 2012, 05:30:24 pm »
Some info......
    Capacities up to 60 m3/hr (264 US gpm).
    Suction lifts up to 8.2 m (27 ft).
    Viscosities up to 5000 cSt.
    Heads up to 75 m (246 ft).
    Available in bronze, cast iron & aluminium casings.
    Air, diesel, electric, hydraulic or gasoline driven.
    Variable speed inverter control.
    Direct coupled or belt drive options.
    Available assemblies include stationary, skid-mounted & mobile options.
pettyofficernick
« Reply #310 on: January 16, 2013, 11:27:17 pm »
Here is the answer to the last part, it is a Megator, or Sliding Shoe Pump, see here for a description of how it works...
http://www.megator.co.uk/sliding_shoe_pump.htm
polaris
« Reply #311 on: March 28, 2014, 09:35:45 pm »
What might be this? Regards, Bernard
RMH
« Reply #312 on: March 28, 2014, 09:40:07 pm »
I believe that might be called a snubber, a device that is fitted to a mooring warp to absorb the stretch loads in choppy conditions
polaris
« Reply #313 on: March 28, 2014, 10:02:43 pm »
No, sorry. It seems these days that it takes 4 seconds to write a reply, and ten mins. to send it!!! LOL. B.
RMH
« Reply #314 on: March 28, 2014, 10:11:09 pm »
roycv
« Reply #315 on: March 28, 2014, 11:05:04 pm »
Hi I agree with RMH the black part is heavy duty rubber and I have seen them in use.
regards Roy
david48
« Reply #316 on: March 28, 2014, 11:10:25 pm »
It is definitely called a snubber sold in all good marine chandlers .Takes the snatch out of the warp if on a bouncy mooring.
RMH
« Reply #317 on: March 28, 2014, 11:13:53 pm »
Knew I was right :-))
pugwash
  • Location: recently left Amble and now in the wet Northumberland hills
« Reply #318 on: March 29, 2014, 12:11:01 am »
Snubbers work quite well - I used to use them on my boat - not as good as the steel spring
type but a lot more quiet when you are trying to sleep at night.
Geoff
Failing to prepare means preparing to fail.
« Reply #319 on: March 29, 2014, 04:09:44 pm »
Oh no >>:-(
Are we back to this?
It's my picture, I'll decide what it is.
Its a snubber :D :D
Welcome back?
Polaris.
« Reply #320 on: March 29, 2014, 08:30:32 pm »
Guys....I think this is great that this thread has been raised again from the dead   :-)).......
Lets carry on  O0.....Derek
polaris
« Reply #321 on: March 29, 2014, 09:53:32 pm »
Dear All,
The title I have for it is a Moring Compensator. Now, not being quite certain whether it has another name already mentioned, I think we will call it a day on this one! Over to anyone!
Regards, Bernard
p.s. Just had/having a very quick look in, much to do at moment.  Thanks Ned, appreciated.
p.p.s. Ned, could you PM me please to advise how I get around the questions etc.. Bob told me in an email but I can't find it!
pettyofficernick
« Reply #322 on: March 30, 2014, 01:56:37 pm »
Try this.....
Jerry C
« Reply #323 on: March 30, 2014, 03:21:48 pm »
Mushroom vent.
pettyofficernick
« Reply #324 on: March 30, 2014, 04:09:37 pm »
Too easy that one....
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14   Go Up
