Author Topic: Tap & Die Sets  (Read 9102 times)
F4TCT
    • My Boat Builds
Tap & Die Sets
« on: November 29, 2012, 10:54:29 am »
Looking at this - http://www.drapertoolbox.co.uk/draper-79205-75-piece-2956-68907
Anyone know if its any good or can recommend another make/set?
Dan
Re: Tap & Die Sets
« Reply #1 on: November 29, 2012, 11:06:27 am »
We have these in my father in Laws workshop
http://www.sealey.co.uk/PLPageBuilder.asp?id=20&method=mViewProduct&productid=5156
Not as cheap but will cut a new thread in a 1950s Fergusson Engine block!
richald
  • Retired and loving it!
Senior member of the OGG (Order of the Grumpy Gits)
Membership Number : 002
Re: Tap & Die Sets
« Reply #3 on: November 29, 2012, 11:36:28 am »
 %)   ...Dan...any HSS [high speed steel] [metric/imperial] [el cheapo]  tap & die set looks to be good value ...but what are you going to use it for? ....................you won't find any BA, ME or metric fine...which are the conventional thread forms used in model engineering {:-{ ........Derek
Fifie
Re: Tap & Die Sets
« Reply #4 on: November 29, 2012, 11:39:46 am »
Try
tapdie.com
Fifie
richald
Re: Tap & Die Sets
« Reply #5 on: November 29, 2012, 11:39:57 am »
From the Amazon page . . .
Unfortunately all the common stuff seems to metric these days . . . :((
Box Contains
  • 9 x Metric coarse dies, sizes: 3 x 0.5, 3.5 x 0.6, 4 x 0.7, 4.5 x 0.75, 5 x 0.8, 6 x 1, 8 x 1.25, 10 x 1.5 and 12 x 1.75--1-inch O/D
  • 8 x Metric fine dies, sizes: 2 x 0.25, 3 x 0.35, 4 x 0.5, 5 x 0.5, 6 x 0.75, 8 x 1, 10 x 1.25 and 12 x 1.25--1-inch O/D
  • 1 x 1/8-inch BSP die
  • 17 x Metric taper taps, sizes: 3 x 0.5, 3.5 x 0.6, 4 x 0.7, 4.5 x 0.75, 5 x 0.8, 6 x 1, 8 x 1.25, 10 x 1.5 and 12 x 1.75--1-inch O/D
  • 17 x Metric plug taps (bottoming), sizes: 3 x 0.5, 3.5 x 0.6, 4 x 0.7, 4.5 x 0.75, 5 x 0.8, 6 x 1, 8 x 1.25, 10 x 1.5 and 12 x 1.75--1-inch O/D
  • 1 x 1/8-inch BSP taper tap
  • 1 x American pattern 1/2-inch capacity tap wrench
  • 1 x 1/4-inch capacity ‘T’ type tap wrench
  • 1 x 1-inch O/D die holder with guide
  • 17 x HSS twist drills, sizes: 1.7, 2.5, 2.6, 2.9, 3.3, 3.5, 4.2, 4.5, 5, 5.3, 6.8, 7, 8.5, 8.8, 10.3, and 10.7 mm
  • 1 x Screwpitch gauge
  • 1 x Screwdriver
Richard
grendel
Re: Tap & Die Sets
« Reply #6 on: November 29, 2012, 11:58:14 am »
I bought a generic set years back and now just buy the sets of 3 for a specific size I want, I have the m14x1 tap and die that matches the spindle thread on my unimat 3.
Grendel
F4TCT
    • My Boat Builds
Re: Tap & Die Sets
« Reply #7 on: November 29, 2012, 12:28:37 pm »
Thanks for the replies chaps.
It would mainly be used on brass and rare occasions alloy.
The 75 piece set should cover my needs, however I may have to get hold of the odd tap for when using BA screws etc.
Dan
Re: Tap & Die Sets
« Reply #8 on: November 29, 2012, 01:38:03 pm »
don't buy one of those draper sets, Dan.........they are rubish.
the sizes actually don't equate to real sizes........a mate has one and his m4 and my old ones that are more than 50 years old.........are different sizes.anything tapped or threaded with his don't fit metric or ba that I have threaded....they are cheaply churned out chinese mush......
your best bet, (like I did, is to pick up old taps and dies for the sizes you most need and want from such places as antique and car boot stalls...old stuff but good quality.....most modellers only need 4/5 sizes(unless you are going into steam.....and then you definately DON'T WANT poor quality steel) and these are easily found..........but made of far superior stuff to chinese steel.
neil.
F4TCT
    • My Boat Builds
Re: Tap & Die Sets
« Reply #9 on: November 29, 2012, 02:23:25 pm »
Cheers Neil.
I guess it goes back to the old saying you get what you pay for..
Did you get my PM about that other bandsaw?
Dan
Re: Tap & Die Sets
« Reply #10 on: November 29, 2012, 02:43:00 pm »
which one Dan...the first one for 400.......replied to that telling you to ask him a few pertenant questions.........but didn't get any others.....that first one looked a good buy so long as the bearings in the wheels and guides are good and the alli wheels aren't cracked.........did you not get it matey.
neil.
Subculture
    • Dive-in to Model submarines
Re: Tap & Die Sets
« Reply #11 on: November 29, 2012, 05:52:05 pm »
Second thumbs up for the Tap and Die company. No rubbish there, and they know their stuff. Pretty much every tap and die for every type of thread you can think of.
F4TCT
    • My Boat Builds
Re: Tap & Die Sets
« Reply #12 on: November 29, 2012, 06:03:18 pm »
Thanks all.  :-))
pettyofficernick
Re: Tap & Die Sets
« Reply #13 on: November 29, 2012, 06:48:53 pm »
Hi there, Chronos do a good range of tap and die sets, mostly of Eastern European manufacture, I have had one of their BA sets for years now and have not had a problem with them.
http://www.chronos.ltd.uk/acatalog/Engineering_Menu_Taps___Dies_Sets_182.html
grendel
Re: Tap & Die Sets
« Reply #14 on: November 29, 2012, 07:24:44 pm »
I think one way to go is to get one of the cheapish sets then if they break replace the sizes you use with decent individual sets of 3 taps.
Grendel
Re: Tap & Die Sets
« Reply #15 on: November 29, 2012, 08:34:15 pm »
the problem with the cheep sets is not breaking, but stretching when you are starting the cut on bar...it stretches so much that you don't get the size of thread you need..........there's no replacement for good high quality tools....they last a lifetime, instead of having to replace cheep and nasty ones that don't do the job properly.
F4TCT
    • My Boat Builds
Re: Tap & Die Sets
« Reply #16 on: November 29, 2012, 08:38:18 pm »
I read a review about the this draper set where the actual tap bar snapped or something along those lines. Certainly something you don't need mid tap!
Re: Tap & Die Sets
« Reply #17 on: November 29, 2012, 10:10:10 pm »
nemesis
Re: Tap & Die Sets
« Reply #18 on: November 30, 2012, 07:10:28 pm »
Hi, Buy cheap is to buy twice, go to Tracy tools, dear yes, but will last a long time. nemesis
Vigo
Re: Tap & Die Sets
« Reply #19 on: December 02, 2012, 12:52:42 am »
the tap and die set you mention is made from carbon steel,I break them real easy,they're ok for cleaning threads up,high speed steel is the only way to go in my opinion.May cost a bit more but will last a lifetime with care,hope this helps
                                                          Terry
F4TCT
    • My Boat Builds
Re: Tap & Die Sets
« Reply #20 on: December 02, 2012, 11:38:46 am »
Thanks all  :-))
I think I will buy the parts ad-hoc, that way i can get the high quality and not spend over the odds on sizes i would never use.
Dan
Re: Tap & Die Sets
« Reply #21 on: December 02, 2012, 12:32:44 pm »
The best cutting tools for most of the materials commonly used in toy making is Carbon steel, but the quality varies. A good Carbon tap will beat a poor HSS one. Don't forget that Stainless is tough on HSS tools too.
  Regards  Ian
john s 2
Re: Tap & Die Sets
« Reply #22 on: December 02, 2012, 08:38:45 pm »
What about Tungsten steel. Taps and dies made correctly from this material will enen handle stainless. John.
Vigo
Re: Tap & Die Sets
« Reply #23 on: December 03, 2012, 07:21:20 pm »
Re tungsten,I have a set of tungsten taps and dies also,but I dont recon much to them.theyre new but dont seem very sharp,I worked in Engineering (machining)for a few years but the only taps and dies I saw and used were HSS.There are sets higher i.e titanium etc but costly and I think more than your requirement,Clark or Osbourn just to name two would be a good choice,have a good day,Terry
F4TCT
    • My Boat Builds
Re: Tap & Die Sets
« Reply #24 on: December 03, 2012, 07:30:27 pm »
Thanks all  :-))
Page created in 0.054 seconds with 21 queries.
