Model Boat Mayhem - Forum
Author Topic: brushless motors  (Read 947 times)
slug
brushless motors
« on: December 06, 2012, 07:58:29 PM »
will brushless motors run under water,i have been told they will????? thank you slug
kinmel
  • Colwyn Bay M.B.C.
Re: brushless motors
« Reply #1 on: December 06, 2012, 08:45:35 PM »
Brushless motors have sealed windings and in sensor-less motors none of the circuit is open to the environment, so a motor in perfect condition with carefully sealed connectors will run under water.
However, bearings and the stators will be subject to corrosion over time.
I have no idea if it will perform as well under water though.
slug
« Reply #2 on: December 07, 2012, 05:41:19 AM »
thank you for the reply,wondering if it was possible to fit one direct into a kort and using a sail winch to turn it 360 degrees????just a thought  ----slug
barriew
« Reply #3 on: December 07, 2012, 09:17:53 AM »
Don't see why not. My airboat flipped and kept running with no ill effects. Might be a serious corrosion problem in salt water, but a squirt of WD40 or similar after each fresh water outing and a thorough drying, it should be OK.
Barrie
