Author Topic: Motors and Batteries  (Read 2310 times)
2051476
« on: December 15, 2012, 09:22:49 pm »
I'm doing research on my next project a 1/96 US Light Cruiser.  A couple of things came up I would like some help on. I'm planning on using a 12V system with two ESC, turning  55mm props, I have used a Rokraft 120 ESC in the past. Now here's my first question on motors was thinking about a MFA 500 Motor with Gear Reduction 2.5:1 but looking at MFA's web site I saw a PLANETRY (EPICYCLIC) METAL GEARBOX. Don't know anything about these but they look like a better transmitter of the motor for torque. Any one use these or give me any advise.  On by Robbe U-47 I have used two 4500mAh  NiMH  wired in parallel. I thought I read somewhere that batteries in parallel sometimes work against each other, any comments. on the 1/96 CL I'm planning on using Acid Gel battery. So run two smaller wired in parallel or one big guy with a lot of amp hours.
 Any comments welcome
 Thanks  John
Re: Motors and Batteries
« Reply #1 on: December 15, 2012, 10:19:02 pm »
Concerning the batteries, you should be OK if you wire in some big diodes to prevent back voltage flow from one to another.
regards
ken
john s 2
« Reply #2 on: December 16, 2012, 07:39:37 am »
Mfa motors can be a bit noisy. There are other options. A read of the forum will help you decide. John.
