Author Topic: planet t5 receivers ... cheaper alternative !  (Read 8984 times)
ian-mccaffrey
  • roll on mayhem at wicksteed 2016 !
« on: January 03, 2013, 12:31:54 am »
hi guys .for some reason or another i keep breaking my t5 receiver  . or dropping them in the water or something . so im wondering if theres a cheaper alternative to buying  the t5 original receiverthats £15 ... and maybe something for cheaper  ...
lets just hope this one floats !!
fire at will ! ... which one is will ?
bikerdude999
Re: planet t5 receivers ... cheaper alternative !
« Reply #1 on: January 03, 2013, 12:55:50 am »
I've been looking lately, as I keep having to change receivers between boats, but as yet I've found nothing.
If you happen to find an alternative please let me know.
AlanT
« Reply #2 on: January 03, 2013, 09:21:42 am »
Good Thread!
I'm also looking for a cheaper and possibly more robust receiver.
One I had just fell apart and one failed to work.
I currently have 6 installed , all binded to a single TX which works very well but they are just a little expensive.
Alan
« Reply #3 on: January 03, 2013, 10:52:21 am »
Excellent thread.
I also would like some more of these receivers.   Would those yellow ones for the Spektrum be easily converted ?
ken
inertia
« Reply #4 on: January 03, 2013, 12:25:39 pm »
Ian-Mac + Alan T
IMHO to try and knock a few pennies off what is already one of the cheapest parts of the whole model is a false economy, not to say a waste of time (unless you have plenty of it). In the UK, Servo Shop are selling the 6 channel 6gm Planet receivers at £67.50 for 5. That equates to £13.50 each - that's just two cans of Halford's spray paint or perhaps a moulded crew figure - while a new Futaba 2.4GHx Rx is almost £67.50 for one! Granted they are a little flimsy but perfectly adequate if you handle them with due respect, and if a new one either falls apart or refuses to work then you have every right as a consumer to either a working replacement or a refund.
Kenny - I wouldn't consider for a moment trying to convert another type to suit. Even if you understand microwave technology, the things are machine-assembled with such tiny surface-mount components that manual reworking without special (aka expensive) equipment would be impossible.
DM
gribeauval
« Reply #5 on: January 03, 2013, 01:35:19 pm »
Have to agree with the above!
Complete Planet T5 combo for the cost of one Futaba receiver = No Contest !!!!
If you want a less flimsy receiver then they also do a 7 channel hard case receiver for £18 and it can bind to all of the Planet range. :-))
http://www.jperkinsdistribution.co.uk/detail.php?JPNO=7710362&activepage=1&Navmain=R/C%20equipment&subcatname=R/C%20equipment%20-%20Planet%202.4GHz
True Lifeboat Nutter!!
Subculture
    • Dive-in to Model submarines
« Reply #6 on: January 03, 2013, 02:31:19 pm »
I like the orange receivers from Hobbyking. These are Spektrum compatible, which used to mean you had to have a Spektrum TX to use them, but now you can get an Orange TX too, which is fully DMS2 compatible. Good spec too. Looks like a boiled sweet though!
« Reply #7 on: January 03, 2013, 02:39:52 pm »
Thanks for all the information.    :-))
Ken
bikerdude999
« Reply #8 on: January 03, 2013, 03:04:37 pm »
Ian-Mac + Alan T
DM
While it may be cheap to buy 5 RX's at once, not all of us can afford/justify nearly £70 on RX's. just because its a cheap set already doesn't mean we can't want to find something cheaper... It takes me months to get enough to save for 1 RX, and when it comes to it there's other things that money can go on...
« Reply #9 on: January 03, 2013, 04:10:31 pm »
Is the orange lozenge from Hobby King?
sailorboy61
« Reply #10 on: January 03, 2013, 04:26:11 pm »
$65 if I remember rightly, and receivers $6
Subculture
« Reply #11 on: January 03, 2013, 04:41:21 pm »
You could light it up with some LED's for nighttime sailing. Should get the attention of fellow skippers, for probably all the wrong reasons!
« Reply #12 on: January 03, 2013, 05:04:26 pm »
I have a slack handful of orange receivers which work perfectly with my spektrum
I have run out of memories and a new Tx at that price is tasty
inertia
« Reply #13 on: January 03, 2013, 05:28:03 pm »
Point taken and no offence intended, but if four or five of you get together then you can effect a saving, if only a marginal one. When you are buying at the low end of the market there's precious little margin for further savings unless you are happy to buy used items. As for your comment that "there's other things that money can go on..." I think it should be obvious to anyone that any hobby which involves a degree of expenditure means that you have to prioritise your money. Grandmothers and eggs spring to mind.
DM
spearfish99
« Reply #14 on: January 03, 2013, 05:59:48 pm »
I have a Futaba FASST Tx that I bought cheap (ish!) from Ebay. I did manage to afford a Futaba Rx for my first setup, but they are expensive.  Needing a second Rx, I bought one of the Orange equivalent which binds and works fine at a fraction of the cost . I also have a FrSky TRF8  Futaba version which is slightly more expensive than the Orange but works just as well
Page created in 0.189 seconds with 17 queries.
