Author Topic: its my VOSPER PERKASA.. the BRITISH F A T P of WW2...  (Read 13277 times)
Krishna
  • aqua plannerrrr....................
« on: January 08, 2013, 09:23:34 am »
Good after noon all respected Modelers..
here, is one of my humble effort to realize the ever potent and classic war machine of WW2.. the British Vosper Perkasa.. as it is hard to explain the history here about this craft, anyone can Google it once.. this craft was driven by three gas turbo shaft engines, in mission, and diesel engines were used to maneur.. so we can simply imagine the potential of this machine.. so, she must be fast.. and became one of the greatest machine in my collection..
this time also, there is no plans to download, but entire scaling is done by orthographic projection, (3 View), and scaled to 30 inches, as my all PT boats are designed in this scale.. a great combination RCying.. this one is 100 % scratch built, except the motor and simple servos..
here i starts from big "0" from my work table.. here i prooves once again, we do not need any extra ordinary tools to make an outstanding,practical  craft.. here my tools are a heavy duty art knife, a point iron, nose plier, and some hand tools..
here we are.. after proper sketching, template is made on a drawing paper.. then on foam board.. this one is fully made of foam board of 3 mm..
as we are scratch builders there is no restrictions.. adding the bulkheads, up to me needs, while keeping all aspects for internal machines..
in sheer ecstasy of being a powerful,mushy,masculine trans woman of substance...
Krishna
Re: its my VOSPER PERKASA.. the BRITISH F A T P of WW2...
« Reply #1 on: January 08, 2013, 04:53:32 pm »
my server is down..
Krishna
« Reply #2 on: January 08, 2013, 04:56:14 pm »
it is too easy to make a hull from foam board.. after thermocoal, to me, foam board is the best material for RC boats.. as scratch building, we can add bulkheads anywhere we likes, while keeping an eye on internal mechanisms..
Krishna
« Reply #3 on: January 08, 2013, 04:58:17 pm »
the hull is ready.. it took about an hour.. time to fix motor.. at first i have to add a water cooling jacket for motor.. this jacket is made from an aluminum C channel..
Krishna
« Reply #4 on: January 08, 2013, 05:01:41 pm »
motor on mount.. can see the water cooling jacket..
motor jacket is ready.. this time, instead of fast epoxy glue, i used PS grey here to seal water jacket..
time to add drive shaft assy.. outer tube is a body of a sketch pen..
Krishna
« Reply #5 on: January 08, 2013, 05:03:17 pm »
inner gaps are sealed with PS grey..
shaft fixed in a convenient angle..
Krishna
« Reply #6 on: January 08, 2013, 05:05:22 pm »
motor installation..  coupling, is a bicycle spoke.. cooling lines- aquarium silicon tubes..
rudder servo- a 9 gram servo..
Krishna
« Reply #7 on: January 08, 2013, 05:09:33 pm »
in detail.. it works 100% perfectly without any fail.. the same line from the motor jacket can be used to cool the ESC also.. so, a 20 amps ESC can use here as it can handle more current with water cooling.. this motor is a powerful one.. it rated at 1300 RPM/Volts, and with a wattage of 275.. perfect for a high speed one...
all intake scoop and exhaust are made of copper tube as my lake is frequented by salt water as shutter opens..
Krishna
« Reply #8 on: January 08, 2013, 05:11:36 pm »
rudder panel is foam board..
before starting a dry run is a must.. so i draw the basic structure on a thick card paper, as trial..
Krishna
« Reply #9 on: January 08, 2013, 05:14:50 pm »
started building.. 90% of the superstructure is paper.. later perfectly water proofed..
Krishna
« Reply #10 on: January 08, 2013, 05:16:17 pm »
one of the extra ordinary feature of this craft is it's super structure.. fascinating..
Krishna
« Reply #11 on: January 08, 2013, 05:17:21 pm »
it is easy with paper..
Krishna
« Reply #12 on: January 08, 2013, 05:18:26 pm »
perfect...
and dry run..
Krishna
« Reply #13 on: January 08, 2013, 05:19:33 pm »
reassuring everything in scale..
Krishna
« Reply #14 on: January 08, 2013, 05:21:05 pm »
adding tail section and exhaust for diesel engines.. from sketch pen body..
first time priming..
Krishna
« Reply #15 on: January 08, 2013, 05:22:54 pm »
antenna mast is a ball point refill..
adding radar base..
Krishna
« Reply #16 on: January 08, 2013, 05:24:30 pm »
steering is made of aluminum wire..
torpedoes are made of glue caps and pvc pipes..
Krishna
« Reply #17 on: January 08, 2013, 05:25:34 pm »
the shroud around prop is same pvc pipe..
Krishna
« Reply #18 on: January 08, 2013, 05:26:42 pm »
primed and primary shade..
Krishna
« Reply #19 on: January 08, 2013, 05:27:58 pm »
torpedoes stands are from foam board.. and in place..
Krishna
« Reply #20 on: January 08, 2013, 05:29:53 pm »
torpedo final coats...
all guns are made of foam board, some refill tubes and wires..
Krishna
« Reply #21 on: January 08, 2013, 05:30:54 pm »
guns in place..
Krishna
« Reply #22 on: January 08, 2013, 05:31:52 pm »
added rivet details..
Krishna
« Reply #23 on: January 08, 2013, 05:33:08 pm »
main gun.. primed..
stand is foam board.. easy to make..
Krishna
« Reply #24 on: January 08, 2013, 05:34:18 pm »
hull primed..
basic water line painted...
Page created in 0.283 seconds with 21 queries.
