Pages: 1 [2] 3   Go Down
Author Topic: rtr yacht £39.99 in LIDL  (Read 16224 times)
Ghost in the shell
Re: rtr yacht £39.99 in LIDL
« Reply #25 on: July 19, 2007, 06:44:46 pm »
well I have spoken to a guy from Housemartin sails' website, dave Creed, he makes keels and rudders etc, so on saturday its a trip there.
new keel a gogo
Go Nuclear!  you'll love it
Ghost in the shell
« Reply #26 on: July 22, 2007, 10:24:10 pm »
sail numbers added and the last of the Lidl decals are gone.
later on Im going to get in contact with reade plastics and get a set of WORKING navigation lights
Ghost in the shell
« Reply #27 on: August 17, 2007, 09:04:26 pm »
under way with the new sails.
with the wind behind her sails, she heals over a bit but given the right wind, nothing too alarming, however with a newer lnger keel planned, that should address that issue.
RantandRave
  • ...don't get me started!
« Reply #28 on: August 17, 2007, 09:25:38 pm »
Looks good. How much have all the mods cost so far?
Ghost in the shell
« Reply #29 on: August 17, 2007, 10:10:11 pm »
so far:
Tx/Rx charger- - 25
rx batt pack - - - 5
new sails- - - - -  20
new keel- - - - -  20
yes i've beaten the price of the boat already, even before the new keel, however the boat was free with the radio!
Ghost in the shell
« Reply #30 on: August 17, 2007, 10:34:23 pm »
by the way I also have 2 now.  the one in the original livery is going to get the same treatment as the original boat, and will have her keel extended first to see how it fairs, it also needs new radio gear.
Ghost in the shell
planned upgrade
« Reply #31 on: August 18, 2007, 01:48:48 pm »
according to the graupner:
item - university club RTR yacht, the original lidl boat https://shop.graupner.de/webuerp/servlet/AI?ARTN=2036
Overall length approx. 515 mm
Beam approx. 120 mm
Overall height approx. 857 mm
All-up weight approx. 930 g
Scale approx. 1 : 25
The UNIVERSITY CLUB is a semi-scale model of a classic 13-metre sailing yacht, as regularly operated in the sailing districts of the North and Baltic Seas. In addition to the rudder, the boat is fitted with a proportional sail setting system for the jib and mainsail to ensure that it can be steered on all courses relative to the wind which are possible with a sailing boat. The strong carbon fibre reinforced mast makes the model easily capable of withstanding the severe stresses encountered under sail. The many detail fittings, including railings, winches, steering wheel, bollards and finely printed sails ensure that the boat looks as good in a glass showcase as on the water. The UNIVERSITY CLUB is of compact dimensions and is supplied completely factory-assembled; it can very quickly be prepared for sailing at your local boating club site.
As I am going to upgrade this lil monter to make her look scale, I ordered several life rings.  well ordering 2x 1/25th sc ring and some smaller ones.  I also measured key parts of the model as well, like railings etc
railings: suitable height (real) 1000mm (1/25th = 40mm measured = 23mm, giving a 575mm height a scale of 1/40 gives a railing height of 25mm, so 23mm @ 1/40 gives 920mm (36")
Steering bollard comes out to about true to scale
so the upgrade to true-scale it will require 40mm high railings though the 20mm gap between the port and starboard railings will be about scale, equating to a 500mm gap real size.
the red life rings are the 1/25th sc ones.
link43mk
« Reply #32 on: August 19, 2007, 08:22:37 am »
are these still for sale
Ghost in the shell
« Reply #33 on: August 19, 2007, 01:19:59 pm »
im not sure check your lidl website or e-bay.
Ghost in the shell
« Reply #34 on: August 27, 2007, 12:15:50 am »
well the upgrades continue, this time the stern railings and the mast get attention.
purchased from READE PLASTICS were some LED spec navigation lights and a stern light, (side-entry), 2x plain stern lights, and some new railings made from a poly-propelene material.  rather than the brittleness of the impact styrene white material, the new poly-propelene ones are bendy and supposed to be more durable, well time will tell, but they certainly do improve the model compared to the low-height original ones.  Nice one there Malcom  ;D ;D
As Yachts have a motor-steaming light, I have decided to use one of the dummy stern lights on the mast to replicate this, as when under sail, this light will not be operating.
Ghost in the shell
« Reply #35 on: September 07, 2007, 04:48:14 pm »
navigation lights on a lidl yacht now installed, I said I would.
thanks to Reade models for the navigation lights
thanks to Dave Milbourn of ACTion Kits for the switch unit
http://www.youtube.com/watch?v=I7wKAWPTyU0
boatmadman
« Reply #36 on: September 07, 2007, 06:18:10 pm »
Ghost,
Unless I am badly informed, you should only be able to see a port or starboard nav light for 90 degrees angle, so as you move from directly in front round to the side, the light should disappear when you are at 90 degrees to the front.
Make sense? hope so!
Ghost in the shell
« Reply #37 on: September 07, 2007, 06:35:52 pm »
the screens were designed for mounting on the side of the hull, not the top of the cabin. what you are seeing there is light from the part of the unit that should be glued to the hull.  it has been screen off now
Welsh_Druid
« Reply #38 on: September 07, 2007, 07:20:10 pm »
Ghost,
Not quite right I'm afraid - the port and starboard lights should have an arc of 112.5 degrees measured from the bows.
Ghost in the shell
« Reply #39 on: September 07, 2007, 07:28:31 pm »
hint Welsh Druid, could you host that pic in one of the main lighting topics, it could be very useful to other people as well as yachters
« Reply #40 on: September 07, 2007, 07:31:12 pm »
Watch out welsh Druid Ghost is threatening to bring that Yacht up to LLanberis HMM me thinks do we know any fit divers to go and get it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Welsh_Druid
« Reply #41 on: September 07, 2007, 07:41:09 pm »
At least , if he stays til its dark we will be able to see which way his boat is going ;D
Don
boatmadman
« Reply #42 on: September 07, 2007, 08:59:42 pm »
thought I might have been badly informed! thanks welshy  O0
Ghost in the shell
« Reply #43 on: September 07, 2007, 11:05:17 pm »
not just 1, oh no
3 of the little beggers
Cargo
« Reply #44 on: September 07, 2007, 11:36:43 pm »
Ok, the boat is cheap... but why not getting a Micro Magic? It sails very well even for its small size, imho the better choice  :)
Ghost in the shell
« Reply #45 on: September 08, 2007, 08:17:24 pm »
in hindsight yes, however it was brought with the heart not the head!
Ghost in the shell
« Reply #46 on: September 08, 2007, 08:18:36 pm »
that aside Jan, it does look tidy when pn the water.  I may at some point install a magic's rig if it'll fit, with her navigation lights on her, she looks quite smart now
Cargo
« Reply #47 on: September 08, 2007, 09:32:44 pm »
Whatever you like Ghostie  :)
Ghost in the shell
« Reply #48 on: September 08, 2007, 09:44:36 pm »
jan it did however sail well in a light breeze, anything more than that its lying on its side, time for some extra weight in the keel
Cargo
« Reply #49 on: September 08, 2007, 11:09:52 pm »
Sorry if you may misunderstood me...  ;)
My first sailboat was a BMW Oracle Racing from Kyosho... looked very well but didnt sailed that well...  :-\
Wish i had payed 100€ for her instead of 200€  >:(
But resold her for 180€  ;D
Pages: 1 [2] 3   Go Up
Page created in 0.1 seconds with 22 queries.
