Author Topic: want to remove paint from fibreglass hull  (Read 8431 times)
Klunk
« on: January 23, 2013, 10:27:15 am »
Have a fibreglass hull that needs stripping. Have removed some with acetone but this takes ages! An internet trawl suggest a paint stripper called citristrip, but does not seem available in the UK (it's  environmental friendly) any ideas what can be used to shift it without damaging the fibreglass gel coat, or sanding or using wirewool!
full time penguin
Re: want to remove paint from fibreglass hull
« Reply #1 on: January 23, 2013, 10:59:29 am »
Fairy Powerspray  :-)) :-)) :-))
pugwash
  • Location: recently left Amble and now in the wet Northumberland hills
« Reply #2 on: January 23, 2013, 11:06:11 am »
klunk I am in the middle of stripping a new hull at the moment - Had a disaster when painting the topcoat on a
destroyer (dont know what went wrong with the paint) but it had to be stripped so I am using cellulose thinners,
painting it on with a brush and wiping off with paper towels.  Has taken about a day all told but done over several days
because of the fumes - Definitely have the window open, but it does work and has left a nice clean hull ready for
priming again. just a light wet'n'dry
Geoff
Failing to prepare means preparing to fail.
chas
« Reply #3 on: January 23, 2013, 11:24:14 am »
Hi Klunk, we've all been in a similar situation. I believe that there is nothing better than elbow grease and a few grades of wet and dry paper, used wet. No fumes and easy to control. With some stripers there is a danger of them reacting with the glass fibre.
Chas
hmsantrim
« Reply #4 on: January 23, 2013, 12:07:38 pm »
      Hi Klunk.
                      can recommend the fairy power spray for the GRP  had a two top coat spray paints that did`nt like each other and had
                      to be removed.  The fairy did the job no affect to the GRP.
                             Frank  :P
« Reply #5 on: January 23, 2013, 12:19:34 pm »
I have used Fairy Powerspray on an ABS Victoria hull and also to remove primer (red antifouling) from a fibreglass cygnus hull.
No problem with fumes and not too messy.
sailorboy61
« Reply #6 on: January 23, 2013, 01:06:18 pm »
Subculture
    • Dive-in to Model submarines
« Reply #7 on: January 23, 2013, 01:15:45 pm »
Old brake fluid works well on a lot of paints
chris gillespie
« Reply #8 on: January 23, 2013, 03:57:19 pm »
i have half followed stavros...
i damped mine with cellulose thinners, probably the wifes nail polish remover would be equivalent, sharpened a trusty chisel and scraped it all off
then a good rub down with increasing grades of paper...i used 240 then 400....
the thinners softened it all, the chisel scraped off surprisingly well....very few scratches to be had.
Klunk
« Reply #9 on: January 23, 2013, 05:31:49 pm »
Fairy power spray is not available in Luton!!! Any other ideas Mr muscle oven cleaner??
full time penguin
Subculture
« Reply #10 on: January 23, 2013, 05:44:33 pm »
Most of these oven cleaners are based on sodium hydroxide- probably better known as causitc soda. You can get that at a chemists, hardware store, or ebay etc. and mix your own solution.
Also handy for unblocking your drains. You do need to be very cautious using it though, as it can cause serious burns and respirtory problems if inhaled.
« Reply #11 on: January 23, 2013, 05:50:18 pm »
Wilkos, Tescos  Asdas all sell it
or are you still bartering or using
cowrie shells in Loo ton??
« Reply #12 on: January 23, 2013, 06:08:30 pm »
great for decoking cylinder heads and pistons as well
Klunk
« Reply #13 on: January 23, 2013, 06:14:24 pm »
Err this is Luton, you know home of the IRA during the 70's, home of radical Muslims now and right wing edf!
full time penguin
Klunk
« Reply #14 on: January 23, 2013, 06:18:37 pm »
And no doubt a moderator will come along and do something to this post!
full time penguin
chris gillespie
« Reply #15 on: January 23, 2013, 06:20:29 pm »
lol.........dont discuss "whale wars" either  :-X
A66
« Reply #16 on: January 23, 2013, 06:26:52 pm »
Hi Klunk Try Panther Paint stripper available in Hitchin from a well known independant Builders Merchant,Brookers,have used this on two glassfibre hulls with no problems.
Steve
« Reply #17 on: January 23, 2013, 06:32:48 pm »
Kenny will be requesting an avatar :D :D :D
Klunk
« Reply #18 on: January 23, 2013, 06:38:41 pm »
My avatar changes by itself and disappears by itself!
full time penguin
Klunk
« Reply #19 on: January 23, 2013, 06:41:13 pm »
Steve
Excellent a trip tomorrow night!
full time penguin
triumphjon
« Reply #20 on: January 23, 2013, 06:53:12 pm »
most modren brake fluid is synthetic or semi synthetic , which hasnt the same effect on car bodywork / paint  . nitromors do sell a specific stripper for use on grp products , but its expensive . FAIREY POWERSPRAY   is available in most good sized supermarkets  at a fraction of the cost and works !
« Reply #21 on: January 23, 2013, 07:10:43 pm »
Klunk DONT DO IT there is every chance it will attack the grp,there is a specific stripper available for grp,failing that you might well be able to get hold of some Model Strip.Plaes do NOT use acetone either as this could also damage the Grp.
Fairy power spray is my FAV for stripping paint off a hull
Stav
Klunk
« Reply #22 on: March 03, 2013, 11:35:59 pm »
Fairy never touched it neither did Mr muscle oven cleaner! Tried acetone gel it spat that off as well! I'm on acetic acid gel at the moment. Do have the panther stuff and that's a last resort!
full time penguin
chris gillespie
« Reply #23 on: March 03, 2013, 11:45:28 pm »
sharp chisel, at the right angle will do a great job , wrong angle itll cut into the hull....i tried it on my first go it was relatively easy...yes i was nervous...but it saved an enormous amount of elbow grease...then use fairy or some other agent to wipe and clean smooth...
its not a popular choice i used acetone on acrylic spray, white spirit on oils and enamels....never had any issue with hull damage, i put the thinner on a cloth and used it adequately not to much it runs and drips etc....i also found where i may have had the accidental deeper gouge, the thinner helped rub and fill to a certain extent..
it worked for me, i may be critisised but ...hey ho
scoop
« Reply #24 on: March 04, 2013, 01:16:46 am »
It's also excellent at dissolving aluminium parts, so make sure they are rinsed with plenty of clean water afterwards. The gas evolved during the cleaning process is Hydrogen so is best done in a well ventilated place or better still outside in a smoking free zone, H2 + Flame = Kaboom !
I'm surprised no one has mentioned good old T cut and elbow grease, much safer than Caustic, Acetone etc  :-))  Cheers Scoop
BMPRS Secretary/Pro www.bmprs.co.uk
PS. There ain't no going back
